Author Topic: [IC] Pixelspace Shadow - 80% TKL | Details Update, GB start at 25th  (Read 11102 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
GB Updates
Colorways
Anodized Silver (Weight Color Options: Anodized Dark Gray/Black/Red/Dark Blue/Purple)
Anodized Dark Gray (Weight Color Options: Anodized Black/Red/Pink/Purple)
Anodized Purple (Weight Color Options: Anodized Dark Gray/Black)
Anodized Ice Blue (Weight Color Options: Anodized Dark Gray/Black)
Anodized Pink (Weight Color Options: Anodized Dark Gray/Black)
Coating Cream (Weight Color Options: Anodized Dark Gray/Black/Red/Blue/Purple/Pink)
Coating Starry Black (Weight Color Options: Anodized Dark Gray/Black/Red/Dark Blue/Purple)
Coating Light Safari (Weight Color Options: Anodized Dark Gray/Black/Red/Dark Blue/Purple)
Coating Red (Weight Color Options: Anodized Dark Gray/Black)
Coating Yellow (Weight Color Options: Anodized Dark Gray/Black)
Inner Lining Color Options
There are six options for the Inner Lining: Red, Purple, Green, Blue, Pink, Black
Weight Options
Two options for the weight: Weight Retro is with a Big Logo, and Weight Future is with a small one.
Weight Retro
Weight Future
Badge Font Options
Badge A
Badge B
Weight/Midframe/Badge Material and Color Upgrade Options
Stainless Steel Silver Mirror
Stainless Steel Black Mirror
Stainless Steel Silver Stone-washed
Stainless Steel Black Stone-washed
Stainless Steel Chroma Sandblasted
Limited Weight/Midframe/Badge Upgrade Option -- Raffle
Difference 1: Limited edition displays some hollowed-out stars on the weight.
Difference 2: The Pixelspace logo is moved to the left front side of the midframe.
Difference 3: The NUMBER (01~99 for worldwide) representing the limited edition is carved on the midframe besides the arrow keys.
Raffle Rules
When purchasing the unit, you are given a chance to participate in the raffle for a chance to purchase a special limited edition upgrade to the weight/frame/badge. It is limited to 49 units worldwide besides units allocated to China only.
If you win the raffle, you acknowledge that you will need to pay an extra $155. This will be invoiced separately. If you already purchased a Weight upgrade, you will only need to pay the difference of $25 (if you purchase the Stainless Steel option) or $55 (if you purchase the Chroma sandblasted option)
Gift
A Metal Keycaps will be included in the package as a gift for everyone who join our GB.
Material: Stainless Steel
Color Options: Black Mirror, Silver Mirror, Black Stone-washed,Silver Stone-washed, Chroma Sandblasted.(Same as the Weight/Midframe/Badge Upgrade Options)
Vendor
ClickClack
EU: Keygem
SG: Ktechs
OCE: Allcaps
Shadow - 80% Keyboard
Designed by Pixelspace Studio
Index
- Intro
- Design
- Structure
- PCB and Layouts
- Colourways
- Specification
- Q&A
- IC Forms & Discord
Intro
Hello everyone, This is ClickClack, today we'll be presenting a keyboard from our old friend Pixelspace Studio. It has been over a year since the last release - the Capsule65! Pixelspace Studio has been established for 3 years now. Thank you all for your continued support and love. Today we want to introduce to you the latest 80% keyboard project - the "Shadow".
Design
▼ A dual color design was decided for this project -  the main case colours are contrasted by the secondary colour which is in the weight as well as the midframe, which can be seen on all sides, as  well as a protrusion at the front and back.
▼ In the badge and the back and bottom weight badge of the keyboard, we tried to deviate from the traditional of exposing light features directly. Instead, the light is diffused through subtle peeks to create a more ambient feel.
Structure
▼ The gasket leaf spring mounting style is still applied, but this time the silicone gaskets have been replaced by gasket socks, with improved rounded tab shape as well.
PCB and Layouts
▼ PCB has two options, hotswap and soldered, 1.6mm non-flex cut and 1.2mm flex cut, both use QMK firmware and are VIA compatible. no LED underglow or RGB, different versions with different layout supports:
└ Soldered: ANSI, ISO, split shifts and backspace support, stepped and standard caps, 6.25 and 7u spacebar
└ Hotswap: ANSI, stepped and standard caps, no split support, 7u spacebar
Colourways
There are two versions offered for this keyboard:
└ All-aluminium version - weight, badge, midframe, case all 6063 aluminium
└ Stainless steel weight version - weight, badge, midframe stainless steel, case 6063 aluminium
▼ Aluminium version comes with anodised colourways as well as coating colourways:
└ From left to right: silver, dark gray and dark purple
└ From left to right: yellow, red, cream and starry night
▼ Stainless steel version has the following colourways:
└ Anodised silver with silver PVD
└ Anodised purple with black PVD
└ Anodised gray with black PVD
└ Red coating with black PVD
└ Yellow coating with black PVD
└ Cream coating with silver PVD
└ Starry night coating with chroma sandblasted finish
└ Starry night coating with black PVD
The kit offers four options, including a regular full aluminum version, stainless steel PVD mirror version, stainless steel chroma version, and stainless steel ice crystal version (which cannot be shown in rendering and will be displayed in physical form during the GB). All color configurations are officially fixed and cannot be customized. The special edition version pictures will be updated here soon :)
Specification
► Materials: 6063 aluminium case - weight, badge and midframe are aluminium/stainless steel depending on configuration chosen.
► Layout: F13 TKL (80%), WK/WKL options offered
► Mount: Gasket mount (gasket socks)
► Plate material: PC, FR4, aluminium
► PCB: 1.6mm, non-flex cut or 1.2mm flex cut, no LED underglow or RGB, has soldered and hotswap versions with different layout supports
► Foam: poron case foam, poron plate foam, PE foam and shims (dependent on PCB thickness – see IC form to vote!)
► Typing angle: 6.5°
► Front height: 18mm (first height 15mm for the protruding midframe)
Q&A
What will be the estimated pricing?
Pricing is still TBD, however finalized pricing will be available before GB.
When will be groupbuy start?
The groupbuy is planned for some time in July, official dates will be released before the groupbuy starts! As usual the groupbuy should be open for a month.
Will this be unlimited groupbuy?
The SS and aluminium versions will be unlimited! However the special edition will be limited to 99 units.
Gallery
Imgur Album
Interested?
This group buy will be handled by ClickClack.io and please contact the platform for more information.
Join ClickClack’s Discord for latest update, discussion, questions:
Fill in Interest Check Form:
Follow ClickClack's IG for other new projects:
« Last Edit: Sat, 25 November 2023, 04:57:29 by ClickClack.io »
Online Rhienfo
  • GOTHETIGES
Re: [IC] Pixelspace Shadow - 80% TKL
« Reply #1 on: Wed, 03 May 2023, 20:46:54 »
Was is the estimated weight, and also will there be prototypes before the group buys start?
Offline NihonCK
« Reply #2 on: Thu, 04 May 2023, 11:48:59 »
streamers have already been contacted, so proto's should show up there soon
    • clickclack.io
« Reply #3 on: Wed, 10 May 2023, 20:52:42 »
Yes, there will be streams and videos before GB starts, please join our Discord for the latest news.
Protos will show up in June or July
    • clickclack.io
Re: [IC] Pixelspace Shadow - 80% TKL | Details Update, GB start at 25th
« Reply #4 on: Mon, 20 November 2023, 08:20:07 »
Since IC post, We have received many suggestions and offer more options for Case, Weight, Badge and so on. Thanks for your patience~
