Author Topic: [IC] Okitoes Keycap GB  (Read 6660 times)
Offline Doris Folkeys
    • www.folkeys.com
« on: Sun, 14 May 2023, 22:48:47 »
-Gb will last 2 weeks which will end on May 27th at 12pm est
This keycap using golden PVD process with 2 layers plating,not like other plating finish only 1 layer which will be easy to peel , we have the quality control for the quality ensure it is durable in the use.
Catch up for the GB,this is the IC Form for you to fill if you want to join .
Or contact ZxZu#0007
/Folkeys#9134 if you have any question.
« Last Edit: Sun, 14 May 2023, 23:06:46 by Doris Folkeys »
We are  keyboard custom agency in China ,doing :
keyboard case machining,pcb design,and help make 3d drawing .
Or message me : Folkeys#9134
Offline MIGHTY CHICKEN
Re: [IC] Okitoes Keycap GB
« Reply #1 on: Sun, 14 May 2023, 22:59:33 »
The wonders of the keyboard world
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #2 on: Sun, 14 May 2023, 23:04:39 »
im retiring from ****posting. goodbye everyone.
Online Rhienfo
  • GOTHETIGES
« Reply #3 on: Sun, 14 May 2023, 23:07:24 »
Just because you can, doesn't mean you should
Offline DuellM
  • Keyboard Fatty
« Reply #4 on: Mon, 15 May 2023, 00:08:05 »
I don’t understand are those feet?
Offline Mr Chrome
« Reply #5 on: Mon, 15 May 2023, 03:11:54 »
I—
“This plastic rectangle is alright. The plastic rectangles on top of it, though...”
Offline Nevrest
« Reply #6 on: Mon, 15 May 2023, 03:18:31 »
Yes... Yes it is...
Offline fpazos
« Reply #7 on: Mon, 15 May 2023, 04:35:52 »
I think that's the kind of group buy where everyone says no but somewhat it becomes very sucessful. Good luck.
Offline xLeHoy
  • weeb board enjoyer
« Reply #8 on: Mon, 15 May 2023, 05:43:04 »
Agree, yes
Offline dgneo
  • Supervillain
« Reply #9 on: Mon, 15 May 2023, 08:48:21 »
we have strayed too far from god's light
Offline talltail
    • Sen
« Reply #10 on: Mon, 15 May 2023, 10:45:24 »
no.
Offline Elendil-7
« Reply #11 on: Mon, 15 May 2023, 20:16:41 »
Yeah, probably best not to go digging on this one...
