Author Topic: Does this 40% layout exist?  (Read 4120 times)
Offline tbe
« on: Sun, 21 May 2023, 04:34:46 »
Any suggestions for a keyboard or kit with physical layout similar to this?
299169-0
« Last Edit: Sun, 21 May 2023, 06:20:02 by tbe »
Offline LavenderB
  • I believe in unix control supremacy
Re: Does this 40% layout exist?
« Reply #1 on: Sat, 10 June 2023, 05:10:15 »
I've seen some hhkb 40%s.
Safa | 1993 UK ISO-DE Model M  | Frog TKL | 3d printed bakeneko | Akko 5075s
Offline Sup
« Reply #2 on: Sat, 10 June 2023, 07:34:45 »
Not sure if a keyboard exist with this layout but, the layout looks so awful to be honest. going this small and staggered i don't see the benefits and the reason for it to exist then because it can.
I went with this layout and never looked back it is super comfortable and feels way more natural.
current
Coming soon
Offline tbe
« Reply #3 on: Fri, 24 November 2023, 19:03:14 »
What keyboards have that exact physical layout, and which one are you on @Sup?
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #4 on: Sat, 25 November 2023, 11:51:27 »
You would probably be looking at a hhkb 40%, something like this - https://geekhack.org/index.php?topic=92259.0 (do not know if this specific project is any good, just showed a board with a similar layout)
You could DIY and make keyboard with the same layout and handwiring and like a 3d printed case and stuff like that, if you want that specific layout I guess.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline Sup
« Reply #5 on: Sun, 26 November 2023, 13:44:08 »
They call it a Corne keyboard. Its a opensource keyboard so you can get all the parts yourself or a kit and build one yourself. I think Boardsource offers the most premium kits.
current
Coming soon
Offline tbe
« Reply #6 on: Sun, 26 November 2023, 18:32:01 »
Thank you Sup :thumb:
