Author Topic: [GB] 70o - WKLFRL GB date: 25th May 2023 (Cancelled)  (Read 4278 times)
Offline Thebloodyez
  • Just a random keyboard builder.
« on: Mon, 22 May 2023, 15:06:38 »
70O fixed wkl frl
[Introduction]
Update:
GB dates: 25th May to 15th June, $420 / AED ~1,542.32 FCFS @ https://sandkeys.me/
ETA for Shipping: Q4 2023
The rectangle details below as following:
[Specs]
Case:
- Layout: 7.5 degree 70% WKL FRL .
- W: 356.613  mm * L: 121.55mm .
- Front H: 19.36 mm, Back H: 31.97 mm.
- Mount: leaf-spring sandwich mount.
- Internal brass weight.
- Plate to top case: 7.8 mm.
- Alignment pillars total of 4.
- AKB feet.
Plate:
- Leaf-spring anodized aluminum plate.
- Thickness: 1.5 mm.
PCB:
- Fixed WKL.
- Thickness: 1.2 mm.
- Soldered only.
- PCB layout support: 10U spacebar, split back, ISO enter,
1.25U left shift and 1.75U right shift. caps_lock and scroll_lock indicator.
- Firmware: QMK, VIA and Vial.
- Support Mx and Alps.
[Internals]
[Prototypes Pictures]
V1:
Notes: The V1 had spacing issues and its been fixed in V2 also the sides changed from 8mm to 4mm
V2:
Albums:
https://imgur.com/a/ah2M97V
https://imgur.com/a/IXaPvPQ
https://imgur.com/a/OpMTofU
Sound test by Baul:
https://clips.twitch.tv/BashfulPolishedPelicanHeyGuys-CFRqQm9D88i4QHz8
Build by Lightningkeyboards:
Sound test by Lightningkeyboards:
[Sales Format]
FCFS 420 USD - 50 moq
sales @ https://sandkeys.me/
- Case colors: Silver, Black, Bright Red and Navy.
- Plate colors: Silver, Red and Black.
Whats included:
- Aluminum wkl top & bottom case.
- Anodized aluminum plate.
- Soldered pcb.
- UDB (universal daughter board) with JST cable
- Screws (extra included).
- Stabilizer shims.
- Hard carrying case.
[Special Thanks]
Special thanks to MENA server members and specially :
- infected for encouragement.
- Bababaul for helping me a lot in case and pcb design notes.
- Racan for making discord thread possible.
- All others sorry if I forget to mention you but really appreciate the inputs.
Thanks for keyboard atelier server members help specially:
- ciplout for encouraging me designing my own pcb.
- mini, fig, hiney, 4pple and quark for helping troubleshoot pcb design.
- Maelk for help with the pcb.
- Blacksimon science sheet helped me a lot in brainstorming.
- Dark & Wilba.
[FAQ]
- Nothing to see here blacksimon... move along.
And thank you for your interest and support.
« Last Edit: Wed, 31 May 2023, 03:32:20 by Thebloodyez »
Re: [GB] 70o - WKLFRL GB date: 25th May 2023
« Reply #1 on: Thu, 25 May 2023, 12:57:41 »
Approved :thumb:
Offline Thebloodyez
« Reply #2 on: Thu, 25 May 2023, 12:59:26 »
Thank you sir!  :thumb:
Offline Thebloodyez
Re: [GB] 70o - WKLFRL GB date: 25th May 2023 (Cancelled)
« Reply #3 on: Wed, 31 May 2023, 03:34:52 »
The 70o GB is cancelled for the time being. Realistically we were struggling for MOQ: we will approach this from a new angle in the near future.
Shout-out to those who purchased, and supported as much as you could. You'll be rewarded one way or another.
« Last Edit: Mon, 05 June 2023, 07:28:57 by Thebloodyez »
