Author Topic: [GB]Domikey JADE  (Read 4148 times)
Offline 。
[GB]Domikey JADE
« on: Thu, 25 May 2023, 02:27:52 »
Hello everyone, this is Fullstop Studio.
After months of communication and preparation, JADE's GB is finally here!
We bring you information about Domikey Jade and its related products.
Here is the GB information:
First is the kit information about domikey jade:
## BASE KIT/Blind Box A/Blind Box B/WHITE-Base Kit
[110USD (for reference only, actual cost fluctuations by agents)]
Base kit has 150 keys, two versions, using icon key. R1, R2, and R4 each have two 1U novelties , R3 has one carriage return novelty, R4 has two 1.25U novelties and two 1.5U novelties. The base kit has two versions: the full-opaque and the full-transparent keys. Also, there are two blind-box kinds of base kit.
Supported:
* MX HHKB, 60%, 65% (one 1.75u Shift), 660 (an extra 2.25u Shift)
* 75%
* 80%
* Supported WKL
* 2u Shift
* UK ISO
[Base Kit](https://imgur.com/FTa45rv)
[Blind Box A](https://imgur.com/QlKAtJE)
[Blind Box B](https://imgur.com/9EY9mmR)
[WHITE-Base Kit](https://imgur.com/YtNzdpO)
## NOVEL KIT
[33USD (for reference only, actual cost fluctuations by agents)]
[Novel Kit](https://imgur.com/HGkwkzw)
## NUMPAD KIT
[15USD(for reference only, actual cost fluctuations by agents)]
* 22 keys
* Compatible 960/980/100% with Base kit
[Numpad Kit](https://imgur.com/zPLUH1u)
## TEXTMOD KIT
[18USD(for reference only, actual cost fluctuations by agents)]
Including:
* 18 R4 text mod keys,
* 10 opaque keys and 8 transparent keys
* 1.25U, 1.5U, 1U
[Text Mod Kit](https://imgur.com/t02ETxE)
## SPACEBARS KIT
[15USD (for reference only, actual cost fluctuations by agents)]
Including:
* The extra B key
* 1.75U, 2U, 2.25U, 2.75U, 3U(One for each) spacebar
[Spacebar Kit](https://imgur.com/eWTK7qG)
And here are some photos of the demo of the Jade which are shot by our clients.
 [1]
[2]
Then comes the news about domikey jade related products
We bring the switch, and cable of domikey jade with the same theme.
## JADE SWITCH
[0.5USD (for reference only, actual cost fluctuations by agents)]
- Switch type: Linear
- Foundry: keygeek
- Stem Material:  Modified POM (By mixing lubricant modification on the basis of POM, a higher smoothness than the original POM can be obtained)
- Top housing Material: Modified UPE (The smoothness is targeted improved on the basis of retaining the wear-resistant properties of the UPE material)
- Botton housing Material: Hardened PA66 (Hardened for greater durability and better sound performance)
- Spring material: 21mm piano steel gold-plated spring custom-made in Japan Seisen
- Pretravel: 2.0±0.3mm
- Total travel: 3.7±0.3mm
- Initial Pressure:  45±2gf
- Bottoming Pressure: 55±3gf
- Lube: Factory lubrication Krytox 205&Krytox 105
- 5-pin PCB mount
[JADE SWITCH](https://imgur.com/evZz1VW)
## JADE HANDMADE CABLE
[42USD (for reference only, actual cost fluctuations by agents)]
Related content of cable
The total length: 1.5m
Luminous paint
Coil bar
A custom patterned nameplate
[JADE HANDMADE CABLE]
https://imgur.com/hGfSS7Q
https://imgur.com/GBuNs8x
https://imgur.com/s0XX73b
https://imgur.com/igbbkkh
https://imgur.com/zhEPeIw
Purchase Channel:
vendors:
Kprepublic(https://kprepublic.com)
Otakeebs(https://otakeebs.com)
Allcaps(https://allcaps.store)
GB’s period: 2023.5.20-2023.7.1
Shipping Date:2023 Q4
(may fluctuate slightly, subject to the specific circumstances of the agent)
« Last Edit: Wed, 31 May 2023, 20:30:20 by 。 »
Re: [GB]Domikey JADE
« Reply #1 on: Fri, 02 June 2023, 12:09:23 »
Approved :thumb:
