Author Topic: [GB] JRIS65 R2 PCB Gasket Mount Customize Keyboard - Group Buy Information  (Read 4103 times)
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Hi Everyone,
Thank you for your support and patience regarding JRIS65 R2. The GB will launch in five days. Please check the following GB information.
JRIS65 R2 Group Buy Information
SKUs and pricing
JRIS65 R2 GB Page
GB Time: 31st May to 12th June
Estimated Delivery: Start packing and sending to vendors and Mykeyclub direct customers in August 2023
All component is compatible with the R1.
Vendor List
US: KeebsForAll
Canada: Ashkeebs
EU: Candykeys
UK: Prototypist
Oceania: SwitchKeys
South Korea: Geonworks
Japan: Basekeys
Singapore: Mecha.Store
Indonesia:KeebsMark
Philippines:Zion Studios
Thailand: NTCH Keys
Malaysia: Rebult Keyboards
Vietnam: MOKB STORE
Taiwan: 鍵盤好貴
Rest of the world: Mykeyclub
Please check the extracted GB info from the vendor you plan to order.
JRIS65 R2 Information
What are the differences between Jris65 R2 and R1?
We have received much feedback about the JRIS65 after they built it. Most of the customer love and enjoy the build and love our Jris65.
And we also received some improved feedback or issues they were having. So we have improved the R2 according to the R1, please check the details below:
- The JST cable has been extended for a better build experience
- Upgraded the material and finish of the screws
- Added a 1.6mm Non-Flex Cut Black core Hotswap PCB.
- Upgrade a piece of Poron Case Foam to Non-Flex Cut.
- The plates has been upgraded to better support ISO compatibility.
- Added the case colors options: Lilac, Orange, Silver, Maroon, Navy Blue, Dark Green, Titanium Grey, Orange&Black, Dark Green&Black.
- Added the PVD Mirror Weight colors options: Blue, Purple, Gradient.
- New limited edition case added: Red and Black.
JRIS65 R2 Renders
Red        Black
Pink        Lilac
Orange        Orange&Black
Maroon        Maroon&Black
Navy Blue        Navy Blue&Black
Dark Green        Dark Green&Black
Black        Silver
Titanium Grey        Titanium Grey&Black
Milky White        E-White
E-White&Black        Dimensions
JRIS65 Specifications
- Typing angle: 6°
- Front height: 21.3mm
- PCB GASKETS structure
- PCB with USB-C daughterboard
- Both PCB and plate adopt flex cut design
- PCB gasket jackets or socks (included as default)
- QMK/VIA Supported (Note: The BT PCB has its drive, so it doesn't support VIA/QMK)
- Support PCB stabilizers
What can you customize for JRIS65 R2?
Case Colors Options
- 2  limited edition case: Red, Black (Only 300 Limited QTY Worldwide)
Highlight reoxidation finish for the chamfered in makes the overall front more three-dimensional and exquisite.
- 5 E-coat case:E-white, Milky White, Pink,  Lilac, Orange
- 6 Anodized Case: Black, Silver, Maroon, Navy Blue, Dark Green, Titanium Grey
- 6 color combos case: Orange&Black, E-White&Black, Maroon&Black,Dark Green&Black, Navy Blue&Black, Titanium Grey&Black
Weight Options
- Anodized Alu Weight: Black, Silver, Gold
- PVD Mirror Stainless steel Weight: Gold, Silver, Black, Chroma, Blue, Purple, Gradient
PCBs Options
- Wired Flex Cut Black core Hotswap PCB( 1.2mm, Multi Layout, support QMK and VIA )
- Wired Non-Flex Cut Black core Hotswap PCB(1.6mm, Multi Layout, support QMK and VIA )
- Wired Flex Cut Black core Solder  PCB( 1.2mm, Multi Layout, support QMK and VIA )
- 5.2 Bluetooth Hotswap PCB,battery included ( 1.2mm, ANSI Layout,  support LDN Software)
Plate Options
- PC/POM/FR4/ALU
- Brass (Add-on only)/Black core FR4 (Add-on only)
Plateless Options
We highly suggest building plateless with 5mm extra plate foam and solder PCB.
The 5mm extra plate foam will bring a more soft typing feel, and the typing sound will be cleaner.
But without the 5mm plate foam, it will also work fine, and the typing feel and sound are very different.
What's in package?
- 1x Full CNC Aluminum Case
- 1x Weight ( Anodized Alu/ PVD Mirror)
- 1x PCB (Flex Cut Hotswap/ Non-Flex Cut Hotswap/ Soldered/ Bluetooth)
- 1x Plate (PC/ FR4/ Alu/POM)
- 1x Type-C Daughterboard
- 1x IXPE Foam
- 1x Poron Plate Foam
- 1x Flex Cut Poron Case Foam
- 1x Non-Flex Cut Poron Case Foam
- 1x Masking paper for PCB
- 1x JST Cable
- 10x gasket jackets
- 20x gasket socks
- 1 Set of PCB stabilizers O-ring
- 1 Set of Footpad
- 1x Silicone pad of battery compartment (We include this as default, so you don't need to consider choosing which PCB to be the default.)
- 1x Battery(Only for the Bluetooth version)
Gift(will not send make-up or replacements)
- 1x USB-Type C keyboard cable
- 1x Carrying Case
Please check the prototype photos below#
- Pink Case with Chroma PVD Mirror Weight
- Maroon + Black Case with Gold PVD Mirror Weight
- Maroon + Black Case with Silver PVD Mirror Weight
- Milky-White + Black PVD Mirror Weight
- Titanium Grey+Black
- Accessories
JRIS65 Review links#
Content-------------Creator Prototype (JRIS65 R2)
Yo_keebs-------------Orange Case+Black PVD Weight
Rx003-------------Silver Case+Silver PVD Weight
hi_keebs-------------Black Case+Chroma PVD Weight
Preston's Thoughts-------------Milky-White Case+Silver PVD Weight
YBBK-------------Limited Edition Black Case + Black PVD Weight
SeungupKBD-------------DarkGreen Case with Gold PVD Weight
bored bear-------------Limited Edition Red Case+ Silver PVD Weight
kittykat.keys-------------E-White Case+Chroma PVD Weight
whnkeys - Custom Tastaturen-------------Pink Case+Silver PVD Weight
get.switched-------------Lilac Case+Purple Weight
Content-------------Creator Prototype (JRIS65 R1)
Alexotos-------------E-White&Black Case+Gold PVD Weight
Keybored-------------Milky-White Case+Black PVD Weight
nearLucid-------------Milky-White Case+Gold PVD Weight
Yo_keebs-------------Milky-White Case+Chroma PVD Weight
Tofutypes-------------E-White Case+Chroma PVD Weight
sviz ify-------------Pink Case+Silver PVD Weight
Clackbait-------------Titanium Grey+Black Case+Black PVD Weight
Shoobs-------------Black Case+Chroma PVD Weight
Mecha Store-------------Maroon&Black Case+Silver PVD Weight
edwardtanujayaa-------------Milky-White Case+Chroma PVD Weight
mmorpg.com-------------Black Case+Chroma PVD Weight
tomshardware-------------Pink Case+Chroma PVD Weight
Mykeyclub Team
We are a platform that integrates creativity and innovative design, helping more studios join this hobby community and bringing more fun and cool products to you guys.
Please participate in our MKC family for more discussions and future updates.
Mykeyclub discord
Mykeyclub Ins
Best Wishes
Mykeyclub Team
« Last Edit: Fri, 09 June 2023, 05:05:15 by Mykeyclub »
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Hi everyone! The GB has only 3 days left, and we have updated the review links. Please check it. :D
