Author Topic: [CLOSED][GB] JU x Domikey JADE keycaps  (Read 23868 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Fri, 26 May 2023, 22:41:34 »
KEYCAP DESIGN
瑾瑜(Pin yin: jin3 yu2) is JU x Domikey JADE theme in Chinese. It stands for beautiful jade in general.
In a Chinese Classic poem The Song of Chu, the author writes '怀瑾握瑜兮,穷不知所示.' (it means that the 'I' cannot find anyone who is able to share same visions or to talk with 'me'.) It reminds Ju of that he lives in the Internet age. JU is able to share and make friends through the Internet.  Therefore, JADE theme is kind of gift from JU Studio to the Community.
 A good and beautiful jade in Chinese culture is clear and bright. It is hard to express such feature in colour and material on keycap.  With many of attempts on colouring, JU eventually get the one which makes him satisfied. With Domikey high-quality ABS translucent plastic, JADE theme keycap comes true.
ASSOCIATED-THEME SWITCH
JU Studio works with Keygeek and brings the JADE theme associated switch to the community. JINYU Switch.
SPEC
  • Switch type: Linear
  • Stem Material: Modified POM (By mixing lubricant modification on the basis of POM, a higher smoothness than the original POM can be obtained)
  • Top housing Material: Modified UPE (The smoothness is targeted improved on the basis of retaining the wear-resistant properties of the UPE material)
  • Botton housing Material: Hardened PA66 (Hardened for greater durability and better sound performance)
  • Spring material: 21mm piano steel gold-plated spring custom-made in Japan Seisen
  • Pretravel: 2.0±0.3mm
  • Total travel: 3.7±0.3mm
  • Initial Pressure: 45±2gf
  • Bottoming Pressure: 55±3gf
  • Lube: Factory lubrication Krytox 205&Krytox 105
  • 5-pin PCB mount
ASSOCIATED-THEME MOUSEPAD
SPEC
  • size: 900x400mm
  • waterproof Jersey surface
ASSOCIATED-THEME CABLE
SPEC
  • The total length: 1.5m
  • Luminous paint
  • Coil bar
GB PAGE
« Last Edit: Sun, 11 June 2023, 22:56:24 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: [GB] JU x Domikey JADE keycaps
« Reply #1 on: Sun, 28 May 2023, 01:35:57 »
« Last Edit: Sun, 28 May 2023, 01:52:28 by KPrepublic »
