Author Topic: [GB] Orbit 65% - Curved,Tadpole, Low Front Height. GB open till 18th June  (Read 29155 times)
Offline Ra66it_AU
    • Najakeys
    Orbit
    Designed by Machina
    UPDATE 28-05-23
    GB OPEN!
    Hello there! I am Ra66it from Australia, today is the first day of the group buy for my project: Orbit by Machina—a 65% keyboard featuring a silicon pin mounting style.
    After dedicating 454 days to this project, I have gained invaluable knowledge from the incredible people within this community. Throughout this period, the Orbit has continued to evolve, adapting and improving with each step of the journey.
    The main idea of the design is to keep the keyboard as slim as possible. Internally, trying to make a clean-sounding keyboard with the least amount of foam.
    That does not mean I will refrain from using foam in any build, by any means. On the contrary, I consider this challenge as an exciting opportunity to explore and push the boundaries of the characteristics I can achieve without relying on foam.
    The external curves and internal weight pattern give me an astronomy vibe, I hope this keyboard is also in your orbit :)
    The look of this keyboard is influenced by the HHKB series (HG variant and Pro2).
    IC LINK: https://geekhack.org/index.php?topic=119018.0/url]
    DISCORD LINK: https://discord.gg/KZ7axT7zKg
    INSTAGRAM LINK: https://www.instagram.com/machina.syd/
    CONTENTS
    0.DETAILS
    1.TIMELINE
    2.VENDOR
    3.PRICE & SALES DETAILS
    4.MEDIA
    5.COLOR RENDER
    6.LAYOUT
    7.PHOTO
    8.DESIGN CHANGELOG
    0.DETAILS
    - Typing angle 7.0°
    - Front height: 17mm
    - Mounting style: Silicon pin/ Tadpole ( 3 hardness options)
    - Screwless exterior design (detachable silicon feet hiding all the screws at the bottom)
    - PCB: Inhouse design with USB-C daughterboard - configurable with QMK/VIA, hotswap, and solder option available.
    - Will come with a matching carrying case
    - Weight:  1.5kg/3.3 lbs built for Aluminium Version
                   2.5kg/5.5 lbs built for Brass/Copper Version
    - Materials:
         - Aluminium Top Case
         - Two bottom case designs:
         - Full PVD Aluminium Bottom Case with 4 internal brass weights
         - Full Brass Bottom Case with clear coat finish
         - Anodized/ E-coated Aluminium Bottom Case (NEW ADDED as IC form suggests)
         - Color Renders: https://imgur.com/a/FFaE7GB
    1.TIMELINE
      1st Mar 2022        Design Start
    10th Oct 2022        Prototype 001 Received & Tested
      1st Dec 2022        First IC post
    25th Jan 2023        Prototype 002 Received & Tested
      6th Feb 2023        Second IC post
    16th Apr 2023        First Prototype 003 Shipped out for review
    28th May 2023       GB open
    18th Jun 2023        GB close
            Q4 2023        Fulfillment
    2.VENDOR
    AU: www.najakeys.com
    South Korea: Geonworks https://geon.works/
    Rest of the world: www.machina.mx
    Sale Format: GB open from 28th May 2023 til 18th June 2023
    Price
    • Anodized Top Case + Anodized Bottom Case                                $349
    • Anodized Top Case + Aluminium PVD Bottom Case                       $389
    • Anodized Top Case + Full Brass Bottom Case (clear E-coated)       $399
    • Anodized Top Case + Full Copper Bottom Case (clear E-coated)     $439
    • All Raw Aluminium Top & Bottom Cases (clear E-coated)               $369
    • Hotswap        +$10
    • E-coat        +$20
    * Prices in USD
    ** By default, comes with full aluminium plate, 70A hardness silicon pins, 1.6mm PCB, and no flex cut on either PCB or plate.
    4.MEDIA
    Lightning Keyboards Build VOD: https://www.youtube.com/watch?v=MbM91RubDVk
    Alexotos:https://www.twitch.tv/videos/1837661817
    DBOKEY:https://www.youtube.com/watch?v=UZ1_dsck4Xk&ab_channel=%EB%93%9C%EB%B3%B4%ED%82%A4DBOKEY
    Avi
    Keybored: https://www.youtube.com/watch?v=aSQ0jrB9S7M&ab_channel=Keybored
    NearLucid: https://www.youtube.com/watch?v=y4epwWdvk2I&t=226s&ab_channel=nearLucid
    Geon
    Makerchun: https://www.youtube.com/watch?v=SqXRDzC2bp4&ab_channel=markerchun
    * will update here once videoes are available
    5.COLOR RENDER
    More Color Renders: https://imgur.com/a/FFaE7GB
    6.LAYOUT
    7.PHOTO
    V1 Prototype photos
    V2 PHOTO
    UPDATE 06-02-23
    V2 Prototype photos
    8.DESIGN CHANGELOG
    V1 Prototype
    - 1.2mm PCB with flex cut
    - 4 screws between the top and bottom case
    - 4 separate rubber feet
    V2 Prototype
    - 1.6mm PCB with no flex cut
    - 8 screws between the top and bottom case
    - Changed to 2 long rubber feet instead of 4
    - Testing Brass Patina
    - Quality of life changes to the PCB
    - Silicon pin positions redesigned
    V2.5 Prototype
    - Can confirm 1.6mm PCB without flex cut is better.
    - Keeping 8 screws between the top and bottom case.
    - Keeping the bezels as slim as V1.
    - Redo long rubber feet molding. (failed last time)
    - Testing Brass Patina (ongoing process)
    - Quality of life changes to the PCB (ongoing process)
    V2 Prototype Exploded View
    Thank you all for reading till the end!
    Vincent - Special thanks for the amazing photos!
    ANZKEEB - Shoutout to my keeb mates, I won't be able to make this without your guys!
    Geonworks - Thanks for helping me smoothen out my first GB!
    Markerchun - Your camera skills are truly outstanding :)
    [/list]
    « Last Edit: Sat, 10 June 2023, 10:09:36 by Ra66it_AU »
    Less is more?
    Approved :thumb:
    Offline Ra66it_AU
      • Najakeys
    Two weeks to go!
    Less is more?
    Offline Ra66it_AU
      • Najakeys
    Just updated the build stream VOD from Alexotots, check it out!
    Less is more?
    Offline Ra66it_AU
      • Najakeys
    DBOKEY video updated
    Less is more?
    Offline POCO Estudio
    i like 65%
    Offline Excalibur1224
    Re: [GB] Orbit 65% - Curved,Tadpole, Low Front Height. GB open till 18th June
    « Reply #6 on: Mon, 09 October 2023, 02:20:57 »
    Am late to this project, and I was wondering if extras would be available for order sometime around fulfillment.
    Offline codog
    « Reply #7 on: Wed, 11 October 2023, 07:55:47 »
    there's always extras just hang around the vendor/designer's discord or whatever to get updates
