Author Topic: [IC] AENA HHKB(60%) - Silicon tube, Poron gasket, Top, Tube top  (Read 4865 times)
Offline Cofcream
AENA
Designed by Cofcream
2nd Prototype Photo
More Pictures
Hello,
I wanted to create a keyboard that satisfies both enthusiasts who prefer a stiff typing experience and those who prefer a softer feel. I thought it would be interesting to incorporate hollow silicone tubes squeezed between the plate. To clarify, the tubes themselves are very soft and squishy, but when they are mounted, they provide a stiff typing experience. However, due to the small contact point between the tube and the plate, they also absorb shock, resulting in a consistent typing experience.
If you prefer a classic feeling, you can also use a top mount on this board, or you can modify the top mount and use a burger mount with the tubes.
For those who enjoy a softer typing experience, you can use the Poron gasket.
Explode
Tube
Tube top
Top
Gasket
Spec
Layout - HHKB(May add WKL and Poker)
Plate - 6063 Aluminum(Silver Anodized)
Housing - 6063 Aluminum(Anodizing, E-coat)
Weight - Stainless steel(Mirror Polish)
PCB - TBD(Will comes with the daughter board)
Color - Lavender, Grey, White(May change)
Typing Angle - 9°
Front height - 19.1mm
Weight - 1.8kg(Unbuilt)
Interest Check Link
Vendor
TBD
Price
Currently estimating $440 for 300MOQ(Solder, Anodizing version)(+$10 for E-coat)
No weight option
Media
2nd prototype, tube top.
Plate Foam : Poron
Pcb Foam : x
Bottom Foam : x
Switches : Vintage cherry Mx Blue Shell + Boba u4t Stem
Springs  : Sprit Multi Stage 60m1
Switch film : Sw v2
Lube : Krytox 203g0
Stabilizers :  Gateron v2 (Lubed 203g0)
Keycaps : GMK Analog dreams
Render
Will add more renders for the color match
« Last Edit: Tue, 30 May 2023, 22:23:52 by Cofcream »
Offline foxmoon
Re: [IC] AENA HHKB(60%) - Silicon tube, Poron gasket, Top, Tube top
« Reply #1 on: Tue, 30 May 2023, 09:31:19 »
Very nice! :D
Offline Boyten8
« Reply #2 on: Tue, 30 May 2023, 19:05:14 »
$440 for what MOQ?
Offline Cofcream
« Reply #3 on: Tue, 30 May 2023, 22:23:13 »
$440 for what MOQ?
Forgot to mention it. For 300 housings.
Offline tactilesbad
« Reply #4 on: Tue, 06 June 2023, 09:55:20 »
$440 for what MOQ?
whew that's definitely too steep
