Author Topic: Trackball replacement for Kensington  (Read 28570 times)
Offline Subdromat
« on: Sat, 03 June 2023, 09:48:01 »
Iam using a Kensington Trackball with 55mm ball. I tried to replace it with a polished stone ball and it doesnt work. Unfortunatly the stone ball is too heavy ( stoneball is apr. 250g  , stock ball is about 100g) and it will persumly damage the ceramic guideway of the trackball.
 My question is:  Is there a way to interchange the original trackball and what kind (material) of ball should be work without damaging the trackball
tx
Re: Trackball replacement for Kensington
« Reply #1 on: Sun, 11 June 2023, 18:46:59 »
A billiards ball should work perfect
