Author Topic: [IC] Enter80  (Read 27032 times)
Offline ProudCat
    • 骄傲的猫
[IC] Enter80
« on: Sat, 03 June 2023, 22:46:21 »
Hello everyone, this is Kezewa Studio. Our first product, Enter67, achieved a great success and received praise from everyone. We believe that you have confidence in our workmanship. Today, we bring you our second product, Enter80, and we hope that you will like it.
The front design remains minimalist, with the addition of a decorative strip on the front end to add a sense of hierarchy.
The chamfered edge from Enter67 is continued below the spacebar.
The back is still a simple weight, certainly there will be multiple material and craftsmanship options available.
There are still up to 13 colors to choose from (11 anodized colors and 2 e-coating colors), so you can always find one to match for your keycaps.
More renders
Mint:
Structure:
Keyboard dimensions (Length x Width x Height)
Keyboard details(standard)
1.Case:6063 aluminum; Weight:copper(sandblast)
2.Decorative strip(choose from the same 13colors as the keyboard)
3.Plate:PC
4.Pcb:Single-mode (1.2mm with flexcut or 1.6mm without flexcut)
5.Typing angle: 7 degrees
6.Mounting method: Gasket + Top
7.Pack bag
8.Plate stabilizers 4+1
9.Accessories:gasket sockets sockets、all kinds of cottons、feet rubber、screwdriver、dustcloth.
10.Ecoating edition add 15 USD
Keyboard extras:
1、Weight:①Stainless steel(sandblast silver、black、and colouful)
②Stainless steel(PVD silver、black、colourful)
2、PCB:triple-mode(wire、Bluetooth、2.4G)
3、Plate:Aluminum、Fr4、Pom
4、Extra Decorative stripe
Price:
More details will be released soon.
Join Discord:https://discord.gg/RQ44F8WHRe
KEZEWA: https://kezewa.com/
« Last Edit: Mon, 31 July 2023, 00:46:12 by ProudCat »
Offline yi first
Re: [IC] Enter80
« Reply #1 on: Sat, 03 June 2023, 23:30:00 »
When will it be on the website? Looking forward to it :)
Offline DirtyGingy
Re: [IC] Enter80
« Reply #2 on: Sat, 03 June 2023, 23:47:50 »
What is the price estimate?
Offline aicyborg
Re: [IC] Enter80
« Reply #3 on: Sun, 04 June 2023, 19:41:04 »
I'd like to see a lot more layout flexibility. A solder PCB and universal plate for stuff like ISO, split RShift, and split BS would be really good - much more important than 6.25u bottom row I think.
« Last Edit: Sun, 04 June 2023, 19:48:50 by aicyborg »
Offline Kevinsunbo
Re: [IC] Enter80
« Reply #4 on: Mon, 05 June 2023, 05:11:34 »
still TBD but maybe around 200 due to different configuration
Offline Kevinsunbo
Re: [IC] Enter80
« Reply #5 on: Mon, 05 June 2023, 05:12:37 »
Yeah layout is important,and the layouts you said are all supported
Offline ktechs
Re: [IC] Enter80
« Reply #6 on: Mon, 05 June 2023, 06:29:14 »
can't wait. let's get this out there!
Offline aicyborg
Re: [IC] Enter80
« Reply #7 on: Tue, 06 June 2023, 21:59:43 »
Can you provide a graphic of the layout options that'll be supported on the plate and PCB, please? It looks like it's fixed ANSI with no flexibility for splits from the photos shown.
Offline ppatches24
Re: [IC] Enter80
« Reply #8 on: Wed, 07 June 2023, 01:26:46 »
No way!!
My Enter67 came in a few weeks ago and its a 10/10 board, surface finish far exceeded my expectations. The coffee color is AMAZING!
I looking very forward to the Enter 80.
Will there be different color options for that top bar?
Offline Bacms
Re: [IC] Enter80
« Reply #9 on: Wed, 07 June 2023, 03:17:37 »
If this supports hot swap ISO than I will take part. Would be nice to understand what is and what isn't supported at this stage
Offline Kevinsunbo
Re: [IC] Enter80
« Reply #10 on: Thu, 08 June 2023, 06:02:36 »
haha got it.
Offline Kevinsunbo
Re: [IC] Enter80
« Reply #11 on: Thu, 08 June 2023, 06:03:38 »
No way!!
Absolutely yes. Really glad you like it.
Offline Kevinsunbo
Re: [IC] Enter80
« Reply #12 on: Thu, 08 June 2023, 06:04:11 »
WIll add a graphic layout
Offline Formulaw00t
Re: [IC] Enter80
« Reply #13 on: Fri, 09 June 2023, 14:21:41 »
#8 says plate stabilizers, is that correct or did you mean PCB stabilizers?
Offline Kevinsunbo
Re: [IC] Enter80
« Reply #14 on: Fri, 09 June 2023, 23:20:27 »
Plate stablizer will be included in the keeb,that means we will send buyers one. And it surely support pcb stablizer as well.
Offline givemecopper
Re: [IC] Enter80
« Reply #15 on: Thu, 22 June 2023, 03:01:48 »
When will you start the GB?
Offline ppatches24
Re: [IC] Enter80
« Reply #16 on: Fri, 23 June 2023, 20:26:32 »
Will we be able to order extras of the strips that go on top of the board? I cant decide between two colors?
Offline HotFishsoup
Re: [IC] Enter80
« Reply #17 on: Tue, 27 June 2023, 11:04:53 »
I love the chamfered edge on the top frame, it lets me have a slightly lower wrist rest to compliment it.
Offline ppatches24
Re: [IC] Enter80
« Reply #18 on: Wed, 28 June 2023, 05:07:46 »
now to decide on white or light green for the upcoming domikey jade set.
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter80
« Reply #19 on: Thu, 29 June 2023, 22:11:29 »
We will provide multiple colors for matching
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter80
« Reply #20 on: Wed, 05 July 2023, 23:11:34 »
We will start GB within this month. :)
Offline RiverL
Re: [IC] Enter80
« Reply #21 on: Thu, 13 July 2023, 05:46:44 »
So looking forward to it  :thumb:
Offline bigmaxnonions
Re: [IC] Enter80
« Reply #22 on: Thu, 13 July 2023, 06:51:41 »
Will there be a WKL version? Also, will PCB be VIA/QMK compatible?
« Last Edit: Thu, 13 July 2023, 07:18:30 by bigmaxnonions »
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter80
« Reply #23 on: Wed, 19 July 2023, 06:52:15 »
Offline aicyborg
Re: [IC] Enter80
« Reply #24 on: Thu, 20 July 2023, 23:29:00 »
Please review the graphic you've added which shows layout support. The bottommost demonstration of your supported bottom row is 0.25u too wide. Furthermore, please label that bottom with exactly how wide your non-standard spacebars will be so people can establish what they need to have to use it.
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter80
« Reply #25 on: Sat, 22 July 2023, 09:10:42 »
Thank you very much for your suggestion.We will review and revise it.
Offline ppatches24
Re: [IC] Enter80
« Reply #26 on: Sun, 23 July 2023, 01:05:50 »
Will the orange be an option to buy?
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter80
« Reply #27 on: Sun, 23 July 2023, 06:57:21 »
Yes,the orange option will be retained and can be purchased.
Offline ppatches24
Re: [IC] Enter80
« Reply #28 on: Mon, 24 July 2023, 02:13:42 »
AWESOME! Thank you!
Offline Michi4793
Re: [IC] Enter80
« Reply #29 on: Sat, 29 July 2023, 14:40:43 »
Discord link says expired, can you send a new one? The board looks interesting
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter80
« Reply #30 on: Mon, 31 July 2023, 00:50:34 »
We have updated the address of discord.
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter80
« Reply #31 on: Mon, 07 August 2023, 00:25:16 »
 ;D ;D ;D ;D ;D
Offline RiverL
Re: [IC] Enter80
« Reply #32 on: Thu, 10 August 2023, 22:47:35 »
Offline garynguyen
    • Tap hoa Phim
Re: [IC] Enter80
« Reply #33 on: Thu, 10 August 2023, 23:13:31 »
Do we have 3 modes version in the future? I have an Enter67 R2 and dont want to upgrade to R3 (3 modes). Considering this one if it has 3 modes.
AMD 5600X - RX 6600XT
Ducky One 2, Leopold 900RBT
Keychron Q2, Enter67, Tofu65, Sunset80, Wind Z75
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter80
« Reply #34 on: Tue, 15 August 2023, 09:03:51 »
Yes,we will have 3 modes version in the future.
Re: [IC] Enter80
« Reply #35 on: Mon, 11 September 2023, 22:11:16 »
Can you start the Group Buy this September?
