Author Topic: A 3-dimensional keyboard design  (Read 66824 times)
Offline wolfv
« on: Tue, 06 June 2023, 20:55:04 »
Here is an interesting paper from the Graduate School of Science and Engineering, Waseda University, Tokyo, Japan, 2016:
A method for using one finger to press three separate keys on a three-dimensional keyboard
https://robomechjournal.springeropen.com/articles/10.1186/s40648-015-0039-6
Offline iso
Re: A 3-dimensional keyboard design
« Reply #1 on: Sun, 18 June 2023, 03:35:02 »
Looks like you'd be limited to 3 "rows", also, other hardware limitations, switches soft enough to not mess up your joints on the long run and small enough to be implemented to work with such design
Offline Mandan
« Reply #2 on: Sat, 19 August 2023, 00:56:51 »
The upper row would have to be adjustable somehow, so people with smaller hands could press a switche on the bottom row without pressing the top one too.
Offline jacobolus
« Reply #3 on: Thu, 23 January 2025, 13:56:10 »
The high key looks pretty ick, but the other two are good. For a third key, the best is to locate the top roughly where the fingertip is in the first image.
For a practical implementation of this idea (that never quite made it as as commercial product), see the DataStealth, https://geekhack.org/index.php?topic=55099.0
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #4 on: Sat, 18 October 2025, 13:25:11 »
Looks similar to how my mouse works...
314956-0
You have 3 buttons per main (index/middle) finger.
The upper one even works two-way (forward/backward).
On a keyboard, you could probably do two rows for the far-key.
« Last Edit: Sat, 18 October 2025, 14:01:20 by TheSoulhunter »
A Ghost From The Past
  • ~ BOOO ~
« Reply #5 on: Sun, 26 October 2025, 21:51:22 »
...and a clay model of the board shape.
Done that as well...
Works like a charm to work out the right position!
315022-0
Offline Adrian Hale
« Reply #6 on: Thu, 20 November 2025, 05:01:17 »
That’s a really interesting concept. A 3D keyboard where a single finger can activate three different keys could open up a lot of possibilities for compact input devices, VR/AR typing, or accessibility tools.
I do wonder how practical it is in real use — the learning curve, whether accidental inputs become a problem, and how fast someone could type once they get used to the depth-based key layout.
If you have the full paper or diagrams, it would be great to see how they solved the sensing and separation of the three input levels.
Offline AllenPage11
« Reply #7 on: Thu, 20 November 2025, 05:24:35 »
This is a fascinating direction for ergonomic design. A true 3 dimensional key layout could address some of the limitations of standard flat or even tented keyboards. I’m especially interested in how the curvature and height variations are determined are they based on natural finger arcs or purely experimental? If you have renders, measurements, or an early prototype, I’d love to see more. This concept definitely has potential.
Passionate about mechanical keyboards, I explore custom builds, key switches, and modding techniques. I share insights on ergonomic designs, RGB setups, and DIY projects. Join me for tips, reviews, and discussions to elevate your typing experience! #MechanicalKeyboards #CustomBuilds
Offline nescio
« Reply #8 on: Tue, 16 December 2025, 06:42:12 »
A generalization of this would be to let a neural network or other kind of statistical model figure out what you meant to type based on movement and disambiguation based on the surrounding text. That way it would be possible to not even need a keyboard anymore. Still, just thinking about the words your want to type should be enough, since your "inner voice" is a signal and any signal can be decoded.
I think if you combine all the latest technology together typing is already obsolete (think rack of  datacenter class GPUs with $100K of sensors ). It's very unlikely that keyboards will exist another 25 years as a mainstream product. Meta presented a precursor version of a limited version of that last year. (Execution and providing the funds to move the needle are to be commended, IMO.)
Offline HenryJames
« Reply #9 on: Tue, 23 December 2025, 05:44:02 »
I agree. As technology improves at understanding intent and signals, typing will likely become unnecessary. Keyboards may stick around for a while, but they probably won’t be mainstream in the long run.
Offline nescio
« Reply #10 on: Wed, 24 December 2025, 07:26:57 »
The https://svalboard.com/ kind of does what OP was talking about, right? It does cost $1000.
