Author Topic: The week of G80-5000  (Read 3523 times)
Offline Laggy-gaga
« on: Sun, 10 October 2010, 11:09:35 »
Another g80-5000 shows up
link
DElayout
used condition
Starts at 1 EURO
Working: Ducky Dragon Blue
Looking for: 356L
For sale:Benchmark DAC1+Stello U3+Amber,RS1i,GS1000i,HE400,HD650,w4r,se535LE
AU only
Offline lmnop
« Reply #1 on: Sun, 10 October 2010, 17:32:59 »
I noticed the G80-5000 has 2 models.
vertical windows keys
vertical function keys
Offline sixty
    • http://deskthority.net
« Reply #2 on: Sun, 10 October 2010, 17:35:45 »
function key one is older than 1995, windows key ones are newer.
Offline lmnop
« Reply #3 on: Sun, 10 October 2010, 17:37:45 »
thanks for that. does the G80-5000 have NKRO?
Offline didjamatic
« Reply #4 on: Sun, 10 October 2010, 18:01:54 »
More than 2 models... don't forget some have alt symbol layouts and vertical/portrait enter keys.
Offline sixty
« Reply #5 on: Sun, 10 October 2010, 18:11:20 »
Quote from: lmnop;232231
Yeah, they all have full NKRO and double shot caps. They are a pretty nice keyboard. I wish you could take off the wrist rest, then it would be my daily driver for sure.
Offline lmnop
« Reply #6 on: Sun, 10 October 2010, 18:13:55 »
is the G80-5700 the Number Pad that goes with it?
Offline sixty
« Reply #7 on: Sun, 10 October 2010, 18:19:44 »
Quote from: lmnop;232242
It seems that was the case with the old models. A few newer models seem to come with G84-3700 (no mode 4) instead.
Offline Laggy-gaga
« Reply #8 on: Sun, 10 October 2010, 21:56:27 »
My friend told me that the G80-5000 can only work with G80-5700, not 3700
haven't test it yet(my 5700 still in German)
Will any1 tell me that?
BTW, the earlier G80 -5000 version (without win key) has a very rare dye model
G80-5000SAMDE
« Last Edit: Sun, 10 October 2010, 22:11:44 by Laggy-gaga »
Looking for: 356L
AU only
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #9 on: Mon, 11 October 2010, 12:01:31 »
Ah, interesting. At least those wouldn't yellow, and durability probably is much the same.
Otherwise there isn't too much in terms of interesting boards on the bay right now, guess it's not a good time of year for that.
Offline Phaedrus2129
« Reply #10 on: Mon, 11 October 2010, 19:21:36 »
What's the going rate on these? M15 territory? Lower? Higher?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline sixty
« Reply #11 on: Mon, 11 October 2010, 19:29:18 »
200-500 EUR, depending on how many asians jump in.
Offline lmnop
« Reply #12 on: Mon, 11 October 2010, 19:56:53 »
Quote from: Laggy-gaga;232336
I have never seen a dye sub pom keycap before. very cool. thanks for posting.
Quote from: keyb_gr;232568
POM has high resistances to chemicals and abrasions. it's stronger than ABS and PBT.
« Last Edit: Mon, 11 October 2010, 20:30:56 by lmnop »
