Author Topic: [IC]Lichicx Silent Switches--Gentile Switches  (Read 3858 times)
Offline Aregs Keyboard
« on: Thu, 08 June 2023, 09:41:05 »
Lichicx XCJZ Lucy Recolor switches is coming!
--[In Stock]Lichicx Gentle Switches
299666-0299668-1
Same Mold but different springs and cheaper
https://nlandkeys.com/products/gentle-switches
Spec:
Silent Linear
XCJZ LUCY RECOLOR SWITCHES WITH DIFFERENT SPRINGS
POK TOP
PA mix with a large portion of GF C5 Bottom
POM with custom silicon silencer Stem(Tripleshot Stem)
Just like the Doubleshot keycap, the tripleshot stem is a stem made of three times injection molding
Total travel 3.7mm
Pre-travel 2.0mm
operating force 49g
bottom force 58g
Single-stage Spring
Manued by Lichicx
5PINS
Pre-lubed
ThereminGoat's review:
Basically the same as Gentle switch, as a reference
https://www.theremingoat.com/blog/lichicx-lucy-switch-review
Our discord:https://discord.gg/J7ymxHKCKR
299670-2299672-3299674-4299676-5
