Author Topic: Keyboard Switch/LED Resoldering - Traditional Pump vs Automatic Pump?  (Read 6578 times)
Offline ShangWang
I'm planning on resoldering my HyperX Alloy Origins switches and LEDs and am going to do soldering in general for the first time.
I was recommended to use an automatic solder pump iron compared to using a traditional pump and iron since it makes it an easier job.
The issue is the automatic iron pump has less precise and wider tips, while the one I have from a kit are much more precise.
There are a large number of small solder joints I would have to do with this job, so as much as the automatic iron pump would help, I'm worried about burning the PCB/damaging it in general with the wider tip.
299773-0
https://imgur.com/a/H3iu7oK
This is the kit I originally bought:
https://www.amazon.ca/dp/B096JWV3HS?psc=1&ref=ppx_yo2ov_dt_b_product_details
This is the automatic pump I plan to buy:
https://www.amazon.ca/gp/product/B0932TJX9X/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Of course I plan on buying a solder practice kit before trying soldering for the first time on an actual keyboard, but I'm wondering if the reduced accuracy of using the automatic pump is worth it for desoldering AND soldering compared to a traditional iron and pump.
I know it might be a good idea to use each iron separately for soldering and desoldering, but if I had to choose just one, which is more safe/effective for beginners/advanced solderers?
