Author Topic: [GB] S60 HG by Sho - Upgrade Case for the HHKB Pro 2  (Read 18543 times)
Offline hong@RebultKeyboards
  • Rebult Keyboards
    • Rebult Keyboards
« on: Thu, 22 June 2023, 06:19:54 »
Sho is back with another Topre case, this time the S60 HG, a modern-day tribute to the HHKB Pro HG.
GB Start Date: 6 June 2023
GB End Date:
6 July 2023
Estimate Fulfilment: October/November 2023
Designed by Sho, the S60 HG is an upgraded version of the original S60, with an improved aesthetics and material selection. The complex design of the rear makes it costly to manufacture, but without a doubt it makes your HHKB Pro 2 look like no other.
There will be a battery compartment for use with YDKB bluetooth controllers. USB cutouts will fit both mini-USB or Type-C controllers.
If building with a donor HHKB Pro 2, you will need 58 x 1u housings, 2 x 2u housings from either donor boards, Deskeys or Densus, as this does not come with an integrated plate.
If building with total 3rd party components, you will need a EC Pro 2 PCB from Cipulot, Springs, Domes, 58 x 1u housings, 2 x 2u housings, Sliders and Keycaps.
Variants
Aluminum Standard
Anodized Silver 6063 Aluminum Case
Brushed Top Case, Sandblasted Bottom and Rear Piece
Aluminum Sandblasted
Sandblasted, Top Case, Bottom case and Rear Piece
Stainless Steel Standard
316L Stainless Steel Case
Brushed Top Case, Mirror Bottom and Rear Piece
Stainless Steel Sandblasted
Sandblasted Top Case, Bottom Case and Rear Piece
Stainless Steel Mirror
Mirror Top Case, Bottom Case and Rear Piece
Special Edition (Limited to 50 units)
6063 Aluminum Case
Silver Top Case, Red Bottom Case and Rear Piece
Product Page: Rebult Keyboards
If you are familiar with Superbuy, you can also buy direct from Sho on Xianyu. For more details on this, join Sho's Discord with the link at the bottom of the post.
Price: Due to the higher price, it can vary depending on the platform and currency due to fees, but generally, the Aluminum variants are $500+ while the Stainless Steel variants are $800+. In the native currency of Rebult Keyboards, the Aluminum Variants are RM 2400 and the Stainless Steel variants are RM 3750, RM represents Ringgit Malaysia.
Prototype Images:
[Finishing in prototype pictures do not represent the final finishes of the GB units]
From Lensoflucas:
https://imgur.com/gallery/6fHTIxA
From Snayee:
https://imgur.com/a/pV1jtR3
From Sho:
https://imgur.com/a/uIBBRZG
Prototype Builds - Full Alu with Brass Plate:
Vid by Lensoflucas - https://youtu.be/K9kWKRQTB70
Vid by Snayee - https://youtu.be/FQgg5L_Y3x0
Sho's Discord Server: Join Here
Rebult Keyboards' Discord Server: Join Here
Re: [GB] S60 HG by Sho - Upgrade Case for the HHKB Pro 2
« Reply #1 on: Fri, 23 June 2023, 11:18:55 »
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
« Last Edit: Fri, 23 June 2023, 11:25:08 by HoffmanMyster »
Offline hzh0525
« Reply #2 on: Tue, 04 July 2023, 10:43:54 »
Cool!
