Author Topic: [Preorder]Keylice 65%--Dual mode Alice style keyboard with arrow key, 7.4-8.31  (Read 26809 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
Keylice - Alice 65%
Designed by Kenny 42 Studio
Intro
Greetings keyboard friends.
The preorder of Keylice 65% is ready to start now, according to your feedback we have changed the price from 340$ to 320$, and there is also a carrying case in the kit for every customer who purchase the keyboard.(Check the kit content at the end of the post.)
If you have anything question please don' t hesitate to ask us in the comment. :D
Designs
About appearance:Due to the designer's love for the layout of Alice and the rigid demand for Bluetooth connection, Kenny 42 studio designed this keyboard called Keylice. The designer believes that the Alice layout is already eye-catching enough in appearance, and the slender appearance adds a sense of softness for it, so there is no more personality elements are added.
About layout: The original intention of Keylice's layout design is to serve more people's demand, and users can adjust the layout according to their own needs. Therefore, on the basis of the arrangement of Chocolice, Keylice retains the middle 1U Fn key of the standard Alice layout, and adds 2.75u shift and split backspace.
About weight: In order to echo the bottom case, the shape of the weight has changed from the original rectangle to a trapezoid with both sides parallel to the extension of the bottom case, which can make the weight looks less dull and boring to a certain extent, and increase the sense of vitality.
Reviews
YBBK
nearLucid
nessasaurus
Febust
edwardtanujayaa
The difference between final products and prototypes
1. Larger weight chamfer.
2. Changed the shape of the screw fixing place of the plate
3. The rgb patch light is transferred from the original "~" key to "caps" key.
4. For prototypes, the Top mount is pre-installed with 0.3mm gaskets to ensure that the structure does not conflict. This will be further improved in the GB, and it can be used without gaskets.
Prototype Video
Unboxing & Assembly & Sound Test
Prototype
Anodized Ice Blue
Anodized Silver
Anodized Black
Anodized Gray
E-White
PCB Features
Flexibility:No felx cuts
PCB thickness: 1.6mm
Bluetooth solution: Lotlab solution
Connection method: wired, Bluetooth 5.0
Switches installation method: Solder, Hot-swap
PCB material and process: imported black core immersion gold transparent ink
Mount: Gasket mount (whole plate/half plate/plateless), Top mount (whole plate/half plate)
Key layout: multi-layout Alice ( both hot-swap and solder PCB support multi-layout)
Hotswap PCB
Solder PCB
What can you customize?
Cases Color
Anodized: Ice Blue/Silver/Gray/Black
E- coat:White
Ice Blue
Silver
Gray
Black
E-White
Weight
Anodized aluminum (Black, Ice Blue, Silver) + High-gloss chamfer (Silver, Gold)
Stainless steel PVD: Silver/Black
Silver
Black
Crack Stainless steel: Black
Sandblasted electrophoretic brass
Add On
Plate, Walnut hand rest, Dual-mode PCB
Whole Plate: PC, FR4(TBD), Alu
PC
Alu
Half-Plate: FR4(TBD), Alu
Alu
Walnut Hand Rest
Explosion Diagram
Specification
Typing Angle: 8°
Layout: Alice 65%
Size: 356.89mmx 127.92mm x 35.71mm
Weight: 2.15kg (without switches and keycaps)
Case Material: Full CNC 6063 Aluminum
Surface process Electrophoresis/Anodized
Front Height: 18.95mm in the middle, 21.1mm on both sides (including the exposed part of the foot pad: 1.30mm)
Default Plate: FR4
Kit Content
Case*1
Weight*1
PCB*1
FR4 Plate*1
Poron pad between PCB and plate*1
IXPE pad*1
Poron bottom pad *1
PC battery compartment cover *1
Insulation pad*1
Insulation pad*1
Ipex antenna*2
3000mAh battery*1
Keyboard carry bag*1
Foot stickers*2 sets
Gas silica gel
Screws
Preorder Information
Preorder Time: 10:00 AM July 4th to 10:00 AM August 31st, 2023 GMT+8 (The customer who purchases before August can have a gift of walnut hand rest. )
Estimated Delivery Time: 2 months after Preorder end(The customer who purchases before August can get the product earlier.)
Sale format: Unlimited
Early Bird Price: From 320USD
Vendor
EU: Keygem
The rest of the world:Velocifire
Follow us for the latest information and more discussion about Keylice! ;)
« Last Edit: Mon, 28 August 2023, 01:49:42 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
Offline john08099
  • Velocifire MK
Approved :thumb:
Thank you!
Offline john08099
  • Velocifire MK
Hello everyone, Keylice65 GB is coming to an end, we have updated last review made by YBBK. Please feel free to check it above.
The review contains sound test of gasket mount(all foams/ no foam) and top mount(all foams/no foam).
