Author Topic: [GB] Ouroboros  (Read 14572 times)
Offline Bachoo
[GB] Ouroboros
« on: Sat, 08 July 2023, 18:35:15 »
Original Post has been moved to the post below to prioritize updates
Updates will be in a MM/DD/YEAR format:
08/05/2023 -- Project has closed out. It was a really rough one -- so little people bought the board that this is basically a private run lmao. Because of my manu being so kind and striking a deal with us for this GB, as well as I told Mekibo to remove my cut from the project to buy out the rest of the boards. THEY WILL BE MADE. There will not be many if any extras so this board is pretty limited. On the bright side, since there as so little units there qc and speed of the group buy should be quicker than expected.
09/01/2023 -- TOP & BOT pieces are done machining, weights are under CNC now. (Zoomin')
10/05/2023 -- Boards are currently being ano'd :3
11/08/2023 -- All board are finished completely and first pass-through of QC from manu went by smoothly, they should be on route to mekibo, might start shipping out very soon™️
12/07/2023 -- All board on route to mekibo. :3
01/01/2024 -- Boards are still on route to mekibo.
02/03/2024 -- Boards should be shipping out to customers this month.
03/2024 -- GB Concluded.
« Last Edit: Tue, 09 April 2024, 12:17:31 by Bachoo »
Offline Bachoo
Re: [GB] Ouroboros
« Reply #1 on: Sat, 08 July 2023, 18:36:03 »
Ouroboros
Ouroboros (or just Ouro) is a 60% keyboard, with gasket mounting tabs on the PCB itself. The goal of this design was to achieve a flexible-yet-firm typing feel with pleasant acoustics.
"I ain't reading all of that 💀":
GB Date: July 15th 2023 - $400 usd @ 100 units, FCFS only available at Mekibo
Black / Ourple (Ouro Purple) / Green -- WK or WKL
Internals
Am lazy, so enjoy some fusion/kicad screenshots :)
Case Specifications
Typing angle:
7 degrees
Bezels:
7mm top, 5mm sides
Adjusted FH:
~17.42mm (lip) ~19.69mm(front)
EKH:
~21.45mm
Mounting:
Plateless Gasket
Case material:
6063 Aluminum
Weight material:
Polished SS
Weight:
~1.056kg unbuilt
PCB Specifications
Switch support:
MX only
Protection:
ESD + overcurrent
MCU:
ATM
Daughterboard:
Standard Unified
Thickness:
1.2mm
Firmware:
QMK / Via / Vial
Material:
FR4
Designed by:
kbye/studio kestra
Including
- Hard carrying case
- Microfiber cloth
- PCBs
- Poron Foam Gaskets x15
- Daughterboard
- JST cable
- Case hardware
- TX Stabs (1.2mm, no shims required!)
Colors Offered:
Black, Ourple (Ouro Purple), Green.
Supported layouts
You will have the option to choose between WK top or WKL top.
Sale Format
The keyboard will be FCFS available at Mekibo
The price for the keyboard will be $400 USD @ 100 units.
Estimated delivery time will be Q1 2024.
Sustainability
- PCB outline is listed here
- PCB files are available here.
- All hardware will be listed here
Special Thanks
- Armani/Static Archives for design sanitization
- Proto runners for their trust and helping me be less broke ordering
- Nathanalphaman for existing
- Ankit for letting me use his formatting
- My discord server for always being supportive
-You for reading this!
« Last Edit: Wed, 30 August 2023, 10:28:21 by Bachoo »
Offline popkorn62
  • No keyboards for old men
    • Mekibo
Re: [GB] Ouroboros
« Reply #2 on: Fri, 14 July 2023, 17:22:31 »
https://mekibo.com/
