Author Topic: [CLOSED][GB] Molly 60 Keyboard kit  (Read 21905 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Wed, 12 July 2023, 01:18:37 »
MOLLY 60 Keyboard kit Groupbuy
SPEC
Material: Aluminum
Mounting Style: Gasket
Degree:7.5°
Plate: FR4/PC/Aluminum
PCB: Hot-swap Non-flex-cut 1.6mm Thickness Via
Support Connectivity: USB-C
Layout: HHKB/WK
Weight: 1.2kg Case
Material:Spraying Aluminum
Weight Material:
Spraying Aluminum
PVD Brass
PVD Stainless Steel
GB dates: 10th July - 25th July (PST)
Estimated delivery 3 months later when GB closed.
GB NOW
« Last Edit: Sat, 19 August 2023, 21:32:51 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: [GB] Molly 60 Keyboard kit
« Reply #1 on: Wed, 12 July 2023, 01:19:31 »
WK 7u Spacebar layout
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #2 on: Wed, 12 July 2023, 01:20:24 »
Molly 60 Keyboard layouts
Default layout
Supported layouts
