Author Topic: [UK] Bunch of AT102W  (Read 1939 times)
Offline jeyoung
« Reply #1 on: Tue, 12 October 2010, 03:13:06 »
I bought two keyboads from the seller. These are AT102W alright, but his concept of "clean" seems to be flawed. I had to completely dismantle the two, and clean and swap key caps just to make one of them decent and useable. The plates are corroded in places and required WD-40. These are well used keyboards, and the tactile feeling is almost non-existent unless the leaves are tweaked to bring it back.
These keyboards were a nice week-end project and a good opportunity to look at what goes into a mechanical keyboard, but in the end, I've fallen back to using an older IBM rubber dome and a Cherry G84-4100.
Offline pipedream
« Reply #2 on: Tue, 12 October 2010, 05:12:30 »
Thanks for the heads up about these boards!
