Author Topic: [GB] SONIC170 - A fun 65% with knob and LED macro module | GB Extended to Aug 6  (Read 32685 times)
Offline Homiezoned
SONIC170
Hi y’all, it’s me.
Here I bring you the SONIC170, inspired by the TE OP-1 Field synthesizer.
It’s a 65% with a knob and a customizable LED macro module.
Following the feedbacks received in IC, we've removed the crucifix-looking design due to religious concerns.
INFO
Layout: WK & WKL
Mounting: Silicone "Cover" Gasket with leaf spring
Typing Angle: 7 degrees
Front Height: 18.7mm
PCB: Hotswap or Solder / QMK, Via, and Vial support
Colors: 10 Colors
Weight: PVD Black SS or PVD Silver SS
Price: $389
What's included:
Kit content:
Aluminum Top Case
Aluminum Middle Case
Aluminum Bottom Case
Stainless Steel Weight
Plate (Total of 3 plates - 1 main and 2 macro plates)
PCB (Total of 3 PCBs - 1 main and 2 macro PCBs)
Silicone Gasket Strips
Daughterboard and JST Cable
Foam Pack
Screws
10x 4u Light Module Cover
Rotary Module and Knob
Materials:
Top, Mid, Bottom Case: 6063 Aluminum
Weight: Stainless Steel
Plate: Aluminum, Polycarbonate, FR4
PCB: Black FR4
Top case choices:
Hotswap PCB Layout:
Solder PCB Layout:
New Renders
Old Renders
(Please ignore the original crucifix design)
Proto Pics
More eye candy on Imgur!
E-white!
Silver!
Lilac!
Review Videos
Purple Violet by ANTKITS
Lilac by Nansen
Silver by Pudding
E-white by 啥都会一点的夹克
GB Time: July 15th ~ July 30th Extended to August 6th
Delivery: Q1 2024
Vendors:
US: Monke Works
CA: Keyspresso
Japan: Basekeys
SEA: ktechs
VN: MOKB + SoiGear
TH: NTCH Keys
EU: Keygem
UK: Mechboards
OCE: Allcaps
Join discord to receive regular updates
If you have any questions, feel free to comment below
« Last Edit: Mon, 31 July 2023, 03:33:58 by Homiezoned »
Offline Homiezoned
Re: [GB] SONIC170 - a fun 65% with knob and LED macro module | 7/15~7/30
« Reply #1 on: Thu, 13 July 2023, 12:06:04 »
Aug 9th, 2023: Orders have been sent to the manufacture to start CNC.
« Last Edit: Thu, 10 August 2023, 11:48:39 by Homiezoned »
« Reply #2 on: Sun, 16 July 2023, 10:34:03 »
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
Offline metalskim
« Reply #3 on: Sun, 16 July 2023, 16:38:40 »
Hi there, is there any chance of getting more reviewers on YouTube for us Western viewers?  Also, it says it is gasket mounted but none of the Asia reviewers that posted test the flex at all of the gasket.  If you could have some more information and possibly video footage on that, that would be much appreciated!
Thanks.
Offline Homiezoned
« Reply #4 on: Sun, 16 July 2023, 23:57:57 »
Thanks.
Hi, thanks for the question.
1) Due to time constraints, there won't be a review video by a Western youtuber or streamer before the end of the GB period. But there will be after.
2) We made the gasket covers using silicone. Compared to poron gaskets, these are definitely less cushiony. The silicone gaskets provide isolation from the case and a soft typing experience while preventing the board from having the typical "poron gasket sound".
« Last Edit: Mon, 17 July 2023, 00:00:39 by Homiezoned »
Offline techycat
« Reply #5 on: Tue, 18 July 2023, 13:34:08 »
Kinda wish the cross was kept tbh. I loved that part of it. At least give an option to have it or not.
Offline Furki
« Reply #6 on: Tue, 18 July 2023, 16:41:54 »
Nice knob  ;)
gl with GB!
Offline Homiezoned
Offline Homiezoned
Update: GB has been extended until August 6th, grab your unit while you can :thumb:
