Author Topic: [GB] Berceste - WKL65% Keyboard  (Read 28501 times)
Offline Furki
« on: Tue, 18 July 2023, 16:53:15 »
Welcome to the Berceste GB thread!
GB FROM 25.07.2023 TO 09.08.2023!
The GB is live on Oblotzky.industries!
Link to the Furki.customs Discord
Link to the Furki.customs Instagram
Details
Layout: WKL 65% (ANSI and ISO)
Mounting: Plateless PCB leaf spring mount (included gaskets are only to be inserted into the case top!)
Typing angle: 7 degrees
Front height: 14mm (18mm without Cherry lip)
PCB: 1.6mm soldered with daughter board, designed by langerhans
Features: low USB-C position, cherry lip, HG sides
Materials: 6063 aluminum, stainless steel
Manufacturer: Dadesin
Typing test:
Berceste is using a custom PCB designed by langerhans. The following layout is supported:
Colors
These are the final chosen colors. (Color samples are in the imgur gallery)
Beige (powder coating)
Blue (Ano)
Lavender (Ano)
Burgundy (Ano)
Rose (Ano)
Silver (Ano)
Vendors and pricing
Price: 379€ with german taxes (318,50€ without taxes)
Worldwide vendor: Oblotzky.industries
ETA: 4 months after GB ends
Special thanks to:
Mayne for the awesome pictures
langerhans and Manzel for the PCBs and technical help
Oblotzky for hosting this GB! <3
« Last Edit: Wed, 26 July 2023, 07:32:17 by Furki »
Offline Furki
Re: Berceste - WKL65% Keyboard
« Reply #1 on: Tue, 18 July 2023, 16:53:35 »
Reserved!
Moderator note:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
« Last Edit: Wed, 26 July 2023, 12:37:33 by HoffmanMyster »
Offline InspektorCalzone
« Reply #2 on: Mon, 24 July 2023, 10:59:52 »
Awesome Design!
Offline ingenyeur
« Reply #3 on: Mon, 24 July 2023, 11:50:58 »
Super stoked! GLWGB!
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #4 on: Mon, 24 July 2023, 16:04:31 »
GLWGB
Offline Furki
Offline Furki
Re: [GB] Berceste - WKL65% Keyboard
« Reply #6 on: Wed, 26 July 2023, 06:34:44 »
Here are the promised PCB pictures!
And the GB is live so dont forget to check it out!
Offline Furki
« Reply #7 on: Mon, 31 July 2023, 17:12:19 »
Sadly we had to cancel the GB due to not being able to reach the MOQ. Thank you to everyone who showed their support!
