Author Topic: [IC] frost TKL | Top Mount, and Some Snowflakes  (Read 10124 times)
Offline keypport
« on: Sat, 22 July 2023, 08:09:16 »
TKL, Top Mount, and Some Snowflakes
frost is a keyboard inspired by Emilia of Re:Zero.
This is a classic top mount, but PORON washers are used instead of foam.
Media
Keybored
alexotos
Specifications
Mount : Top Mount
Plate : Standard
Weight : 2.5kg (built)
Materials
Top case: A6061 / E-White, Anodizing, Raw Alu
Bottom case: A6061 / E-White, Anodizing, Raw Alu
Badge: A6061 / Anodizing / Raw Alu
Weight: SUS 316 / Clear-coating
Plate: A5052 / Anodizing
PORON washers: LE-20
Front Height & Typing Angle
Front Height: 17.56mm
Typing Angle: 7 deg
Exploded View
Images
Top
WK / WKL
Colors
To be included in a high probability : E-White, Raw Alu
Undetermined : Others
Bottom
Why use PORON washers?
1. The PORON washers are used to reduce the vibration of the plate-pcb
2. Unlike the usual PORON foam, there is no sound absorption effect
Badge
Silver / Black / Light pink / Red / Mustard / Raw Alu
Weight
Plate
Plate features
WK / WKL / ANSI / ISO compatible
Pursuing the symmetry of Alphas
Only silver color, aluminum
IC form
Wishing those who do IC full of happiness
Sale Time
TBD
Price
BasekitPrice ($)
E-White330
Anodizing320
Raw Alu300
Base Kit
Top, Bottom Cases : E-White / Anodizing / Raw Alu
Badge: Anodizing / Raw Alu
SUS Weight: Clear-coating
Aluminum plate: Adnodizing
Carrying Case
Quantity
WK: 25 units
WKL: 25 units
ADD-ONs
Hineybush H87nu + Daughter Board PCB: $60
Hineybush H87nu (Hotswap) + Daughter Board PCB: $70
Extra alu plate: $20
Extra Badge: $12
Extra PORON washers (10pcs): $2
Shipping
LocationsStandard kit ($)
Korea3
East Asia, SEA30
NA, EU, Oceania45
OthersProxy is recommended
FAQ
Does frost support hotswap pcb?
- Yes
Need more information about frost?
Please feel free to visit our server
Thank you
« Last Edit: Sat, 22 July 2023, 08:45:29 by keypport »
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
Re: [IC] frost TKL | Top Mount, and Some Snowflakes
« Reply #1 on: Mon, 24 July 2023, 15:54:47 »
I love Emilia. I hope this can be successful.
Personally though I am not a fan of the curve in the back and the placement of the hairpin in the top right... (I prefer engravings, badges... to be placed on F13 or between arrows and nav cluster.)
However, I support these out-of-the-ordinary design choices. GLWIC  :thumb:
Edit: Hope ano can be improved from what I seen on pictures and what alexotos said in his review
« Last Edit: Mon, 24 July 2023, 16:01:21 by twitchytheinsideman »
Offline unusuaL_
« Reply #2 on: Tue, 25 July 2023, 06:48:10 »
that lighting really isn't doing the ano any favours here
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline garynguyen
    • Tap hoa Phim
« Reply #3 on: Tue, 25 July 2023, 08:57:28 »
I just filled in the form. Watched the videos from alexotos & keybored.
Just wondering what is the different between Alu 6061 and 6063 (sound, anodizing, durable,...)?
AMD 5600X - RX 6600XT
Ducky One 2, Leopold 900RBT
Keychron Q2, Enter67, Tofu65, Sunset80, Wind Z75
Offline doctorboy
    • ClackX
« Reply #4 on: Tue, 25 July 2023, 09:13:39 »
Thanks for sharing your project. Quick question/suggestion from my side:
- If I understood correctly, I believe you are planning to use the USB unified daughterboard. It would be great if you could include that information in the specs.
- Are the poron washers required when using the board? I.e. will we have the PCB touching the bottom part of the case if not using them?
Thanks for all the information and GLWIC!  :thumb:
Offline keypport
« Reply #5 on: Wed, 26 July 2023, 05:07:30 »
Thank you for your support !
Offline keypport
« Reply #6 on: Wed, 26 July 2023, 05:14:56 »
Although there is a physical difference between 6061 and 6063, the difference is not dynamic in terms of keyboard material.
However, the 5052 of the plate is characterized by a softer surface than the 6061.
Offline keypport
« Reply #7 on: Wed, 26 July 2023, 05:19:51 »
1. Yes, it uses the unified dauterboard.
2. The poron washer is optional.
You don't have to use it if you don't want to.
The reason for providing a poron washer is to reduce vibration effects only, instead of using a form.
And even if you use it, the effect is small.
Offline garynguyen
    • Tap hoa Phim
« Reply #8 on: Thu, 10 August 2023, 23:22:07 »
I'm interested in. When will it go live? Or you'll do a raffle?
Offline nuxroskb
    • Keyboard from Vietnamese Maker
« Reply #9 on: Fri, 11 August 2023, 12:33:00 »
Nice !!!
Offline Shunfry
  • #Yolo.
« Reply #10 on: Thu, 14 September 2023, 16:20:12 »
Great board ! I'm in to it !
