Author Topic: Model M Rivet Replacement for Klutzes  (Read 54892 times)
Offline Half-Saint
« Reply #50 on: Sat, 18 June 2011, 14:43:07 »
It's possible although I did try swapping keys from another model M and the result was the same. I also tried a different BS stabilizer with no success. I'll just file it down, I'm sure it'll work. I already thought of drilling through with a slightly larger drill bit to widen the hole. Using a file might be a bit less drastic :)
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
