Author Topic: [GB]Choice65-$120+, Full CNC case, Consistent Typing Experience, Ships in August  (Read 36740 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
Let's make the CHOICE
CHOICE65 - GB OPEN
Designed by Cyberbay Studio
Greetings to all keyboard enthusiasts!
Finally, the GB of Choice65 is about to start! We know many of you are waiting for it since months ago and your wait was worth it!
Intro
We are thrilled to announce the launch of the latest creation of our newly established Cyberbay studio - the Choice65, the first keyboard in our much-awaited Choice series. After months of dedicated hard work and tireless efforts, we are ecstatic to finally present this keyboard to you all.
We understand that not everyone can afford to splurge on high-end keyboards, and that's why we have planned to introduce more budget-friendly options in our Choice series. Our ultimate goal is to make custom keyboards accessible and affordable to those who wish to delve into the world of custom keyboards and bring entry-level customization kits to the market that are on par with mass-produced keyboards, without compromising on quality.
Now, without further ado, let's take a closer look at the Choice65 and make the choice!!! ;)
Prototype
White(E-coat)+Copper(Anodized)
Forest green(Anodized)
Wine Red(Anodized) + Black(Anodized)
Royal Blue(Anodized)
Pink(Anodized) + White(E-coat)
Content Creator
E-white+Copper
Alexotos
Akeynote
The Keebs Store
FL__TWHITE
Edwardtanujayaa
Pink + E-white
Maker Mods
Mangoboba
Wine Red + Black
studio20creations
Captain.sterling
Royal Blue
Keybored
Yo_keebs
Please stay tuned!  :D
Designs
Appearance
From the beginning, we wanted to create a simple and elegant keyboard with a good typing experience. By constantly adjusting the aspect ratio of the overall shape and the thickness of the frame, it was finally determined:The left and right frames are slightly thinner than the top and bottom frames, and the corners of the four sides are R2 fillet, making the turning point appear softer. The bottom weight consists of a large area of PVD stainless steel and a diamond-shaped transparent e-coat brass badge.
Comfortable feel of case
A low price for us doesn't mean we compromise on materials or workmanship. Relying on a strong supply chain, we still use 100% Full CNC 6063 aluminum, and adopt our last well-received DolphinS75 case coating process, which can definitely let you experience a silky smooth touch feel !
Consistent typing experience
We did not use the plate gasket mount. Instead, the poron pad between PCB and plate is used to replace the existing bottom case gaskets by extending and lengthening. Meanwhile, a 2mm plate poron pad is added on the plate to replace the top case gaskets. Therefore, the force point is evenly distributed, it can obtain a very consistent typing experience. At the same time, this mount can greatly reduce the cumbersome process of assembly.
5 Case Colors To Choose
We will choose 4-5 kinds of colors according to your feedback.
2 Anodized case colors
Forest Green
Royal Blue
3 Combo Case Colors
Pink(Anodized)+White(E-coat)
Wine Red (Anodized)+Black (Anodized)
PCB Features
-Black core
- 1.2mm thickness
- Hotswap PCB (ANSI)
- With daughterboard
- Support VIA
- Support stepped caps lock
- Support 6.25u, 7u spacebar
Hotswap PCB
Add On
Hotswap PCB
Foam Kit
Anodized Silver Alu Plate
Specification
Case material: 100% Full CNC 6063 aluminum
Case coating process: Anodizing, Electrophoresis
Mount: Gasket mount
Typing angle: About 7°
Front height: 19.8 mm
Size: 314.15 * 110.1 mm
Weight: About 1.2kg (excluding switches and keycaps), 1.4kg (including switches and keycaps)
Support Plate: PC(default), Alu(all plates only support ANSI layout)
Layout: 65%
Explosion Diagram
GB Information
GB Price: From 120USD
GB Time: July 26th-August 10th 2023
Sale Type: Prestock
Limit Units: 700
Estimated Delivery Time: About 15 days after the GB ends
Vendor
Vendor GB time: July 12th - August 10th, 2023
CA: Deskhero
EU: KEYGEM
UK: Mechboards
KR: Monstargear
JP:  Yushakobo
SG: KTECHS
MY: Rebultkeyboard
TH: NTCH Keys
VN: The Keebs Store
PH: Zionstudios
AU: CLS TECH
US and the rest of the world: Velocifire
The GB time for US and the rest of the world: July 26th - August 10th
Epilogue
Choice65 is the perfect blend of form and functionality, boasting a sleek and minimalist design that is sure to turn heads. Its 65% layout makes it compact and easy to carry around.
In conclusion, we are confident that the Choice65 will exceed your expectations and provide you with an unparalleled typing experience. We hope you enjoy using it as much as we enjoyed creating it.
Thank you so much for your time and support. We look forward to bringing you more exciting products in the future!
Welcome to check the Product Page to subscribe this keyboard! We will inform you via email when the GB start.  :D
Welcome to join our Discord for more discussion, latest update and questions! :)
« Last Edit: Thu, 03 August 2023, 22:24:04 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
Offline john08099
  • Velocifire MK
The GB will close soon, don't miss it if you like Choice65! :D
