Author Topic: [IC] Krush65 (Keyboard + Crush) Update: GB is open!!!  (Read 80937 times)
Offline nuxroskb
    • Keyboard from Vietnamese Maker
Re: [IC] Krush65 (Keyboard + Crush) Update: GB is open!!!
« Reply #50 on: Sat, 18 May 2024, 11:21:23 »
The aluminium weight is the same material as the case, but it is just coloured in a copper look?
Yes, it has the same color as copper
Offline Nerrion
« Reply #51 on: Mon, 22 July 2024, 03:03:28 »
Hi, any update on the GB?
Offline Fluxius
« Reply #52 on: Mon, 22 July 2024, 05:59:20 »
The updates are in nuxros' discord.
