Author Topic: [IC] IQUNIX SUPER Hanna 65 | Unleash the aesthetics of classic stripes!  (Read 2145 times)
Offline iQunix
IQUNIX Super Hanna 65
Welcome back to IQUNIX Super! We’re thrilled to introduce the Hanna 65, IQUNIX Super’s latest premium mechanical keyboard.
Please fill out the IC Form below to let us know your preference.
CLASSIC STRIPE ELEMENTS
Exquisite Retro, Never Out of Date
The biggest design highlight of Hanna 65 is the use of the classic stripe elements, which is relatively rare in the current custom keyboard kits on the market.
And the unique aesthetic design is always one of the important reasons why IQUNIX Super can stand out from many brands.
We chose a 65% compact layout and a retro green color scheme to match Hanna 65, adding a sense of design and refinement to the striped elements on the keyboard.
We engraved stripes on the top case of the keyboard, the inside and the outside of the bottom case, the stripe depth of the top case will be deeper than that of the bottom case.
Besides, there are two different texture forms of stripes on the outside of the bottom case, and the color depth will change under different light angles.
More importantly, each bottom case texture needs at least an hour of the complicated CNC engraving process.
Better product quality always means more expensive costs and higher technical requirements, but we never compromise on quality!
CREATIVE CUSTOM LETTERS
Exclusive Logo, Only For You
There is an eye-catching customized letter in the upper left corner of Hanna 65, and you can choose your letter according to your preference,
leave your exclusive imprint on Hanna 65, and make it a personalized keyboard tailored for you. Also, it can be a great gift for your family, friends, and loves ❤.
In addition to the default "H", we plan to provide more personalized letters as an extra option for the group buy.
Please fill out the IC form to tell us which capital letter you like the most among the 26 letters.
GASKET MOUNT DESIGN
Thocky Sound, Smooth Typing
In order to obtain a better sound solution, Hanna65 still adopts the popular gasket structure and also comes with a
standard foam kit (poron foam, IPEX switch pad, and poron case foams) to meet a "thocky" sound demand and make typing a pleasure!
EIGHT COLORWAYS FOR IC
CNC Craft, Anodized/E-coating
Crafted with high-quality CNC-machined aluminum alloy, resulting in a finely polished surface that showcases gentle curves, enhancing the keyboard's retro elegance.
Anodized or e-coating coloring techniques are employed to ensure both the texture and durability of the keyboard.
Eight case colors for IC: Green, Navy Blue, Purple, Gray, Creamy, Alice blue, Yellow, and Sapphire Blue. Please indicate your preferred color in the IC form.
SELF-DEVELOPED SOFTWARE
Tri-Mode With IQUNIX Firmware
In terms of software, we are committed to the original design, so our priority is to provide the tri-mode PCB with IQUNIX software.
We spent a lot of time on independent development, and IQUNIX firmware can meet most of the user needs compared with VIA.
An efficient, intuitive, and user-friendly experience has always been the core concept of our firmware design.
VARIOUS PLATE OPTIONS
Aluminum / FR4 / POM
The default plate for Hanna 65 is made of FR4. However, we also offer two additional plate materials, each with different hardness levels.
You can choose the plate material that best suits your personal preference.
ALUMINUM KEYCAPS
SPECIFICATION
Typing angle: 6.5°
Aluminum Case
Gasket Mount
PCB-Mount Stabilizers
Connectivity: Bluetooth 5.1 / 2.4GHz / USB-C
Dimension: 342.2mm*128mm*22mm (front height)
Software: IQUNIX Firmware / QMK Firmware
*Keyboard kit does NOT include switches and keycaps.
Please note that all details and specifications are subject to change prior to production.
IQUNIX reserves the right to modify any information provided.
All product images displayed are for illustrative purposes only. Please note that all details are subject to change prior to production.
We will be updating more pictures and videos in the near future.
« Last Edit: Mon, 07 August 2023, 03:33:12 by iQunix »
