Author Topic: [IC] Batik75 - 75% Wireless Aluminum with LCD Screen  (Read 9129 times)
Offline williamsnig
« on: Tue, 01 August 2023, 00:20:34 »
[IC]
Live 1-25 August
Inspired by one of Indonesia's most popular heritage, we present you the Batik75 by Noir Gear
301062-0" alt="" class="bbc_img" />
IC Form: https://forms.gle/2NCXo4TGrRQoGFmB8
301064-1" alt="" class="bbc_img" />
301066-2" alt="" class="bbc_img" />
301068-3" alt="" class="bbc_img" />
301070-4" alt="" class="bbc_img" />
301072-5" alt="" class="bbc_img" />
301074-6" alt="" class="bbc_img" />
More detailed pictures:
Imgur: https://imgur.com/gallery/DlMTg5R
Noir Gear website: https://www.noirgear.com/products/ic-batik75-ic-open-1-august-25-august-2023
Google Drive: https://drive.google.com/drive/folders/1F7NnG58nNYexiln7enghHNUCyRGJK87O?usp=drive_link
Batik75 stock configuration:
  • 135*240 TFT LCD
  • BT, 2.4GHz, and wired connectivity
  • 3000mAh lithium polymer battery
  • VIA/QMK compatible PCB, plus optional Noir software for LCD screen settings
  • 6° typing angle
  • ANSI layout
  • Gasket mounted (poron sheet)
  • Polycarbonate plate
  • Plate foam
  • PCB foam
  • Case foam
*This is a barebone kit*
« Last Edit: Tue, 01 August 2023, 01:17:58 by williamsnig »
Offline aicyborg
Re: [IC] Batik75 - 75% Wireless Aluminum with LCD Screen
« Reply #1 on: Tue, 01 August 2023, 17:53:20 »
we have zoom75 at home
Offline LavenderB
  • I believe in unix control supremacy
« Reply #2 on: Wed, 02 August 2023, 09:51:16 »
Interesting. I'm curious to see what a prototype would look like.
Safa | 1993 UK ISO-DE Model M  | Frog TKL | 3d printed bakeneko | Akko 5075s
Offline williamsnig
« Reply #3 on: Thu, 03 August 2023, 04:48:36 »
I'll post the prototype soon, we're still tweaking the case and PCB design
