Author Topic: [GB] MKC75 Three-in-one Structure Custom Keyboard USD99+| Limited In-Stock Sale  (Read 47350 times)
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Hi everyone!
It's been a while. We're excited to inform you that the MKC75 is currently available for in-stock sales.
If you missed it during our previous pre-order, don't miss out this time!
MKC75 In-Stock Sales Page
Sales Period: From June 7 until sold out.
Delivery Time: Orders will be shipped within 1-2 business days after placing the order.
Promotion Gift: Purchases made during the first week will receive A Super Cute Deskmat as a gift!
The following is the original post
Hello everyone,
First and foremost, as MKC's inaugural independent project, we'd like to express our gratitude for the tremendous support. We aim to give all our customers an even more excellent thank you. We are thrilled to announce that due to the sales meeting our expectations, our team has decided to include an additional bonus for this presale - the MKC Stabilizer Set. With just one week remaining until the PRE-ORDER end, don't miss out on this fantastic pre-order purchase and Bonus.
MKC75 Pre-order Information
MKC75 Pricing
MKC75 Pre-order Page
Pre-order Time: From August 5th to August 31st.
Estimated Delivery: Start packing and sending to vendors and Mykeyclub direct customers around November based on the final order QTY.
Vendor List
US: KeebsForAll 7 PM PDT 4th August
US: Cannonkeys 10 PM ET 4th August
Canada: Ashkeebs Midnight PST (GMT-8) 5th August
UK: Prototypist 9 AM BST (GMT+1) 5th August
Germany: Candykeys  6 PM (GMT+2) 6th August
Spain: ELOQUENTCLICKS 10 AM (GMT+1) 5th August
Italy: Coffeekeys 12 AM (GMT+2) 5th August
AU: SwitchKeys  5th August
South Korea: Geonworks 7 PM (GMT+9) 8th August
Singapore: Mecha.Store 10 AM (GMT+8) 5th August
Japan: Basekeys 5 PM (GMT+9) 5th August
Vietnam: MOKB STORE  8 PM (GMT+7) 5th August
Philippines: Zion Studios 8 PM (GMT+8) 5th August
Malaysia: Rebult Keyboards 8 PM (GMT+8) 5th August
Indonesia: KeebsMark  21:00 PM WIB (GMT+7) 5th August
Thailand: NTCH Keys 5th August
Bangladesh: KeyB 8 PM (GMT+6) 5th August
Argentina: LATAMKEYS 6th August
Colombia: Stiutech 9:00 PM (GMT-5) 4th August
Taiwan: 鍵盤好貴  9-10 PM 5th August
International: Mykeyclub 10 AM (GMT+8) 5th August
MKC75 Information
MKC75 Renders
Milky White        E-White
Pink        Lilac
Orange        Orange&Black
Black        Brown
Grey        Grey&Black
Wine Red&Black        Deep Blue&Black
Green        Green&Black
Silver        Silver&Black
E-White&Black        Black
Features
-Supports Caps Lock Indicator Light
-100% processed using CNC machining with 6063 aluminum case
-Compact 75% layout
-Three-in-one structural design( Top Mount, Plate Gasket Mount and PCB Gasket Mount )
-Supports tri-mode PCB(Wired, Bluetooth and 2.4ghz)
-Supports Plate, Half Plate, and Plateless Build
-Supports Rotary Knobs components and Light Signs, which are also compatible with JRIS75 Rotary Knob/Badge/LED Light Sign
-Supports Alu Internal Weight
-Multiple configurations available
-2 x 2200mha large battery capacity
MKC75 Specifications
- Typing angle: 7°
- Front height: 18.5 mm
- Material: Full CNC 6063 aluminum
- Dimensions: 320*134.4*33mm
- Three-in-one Structure: TOP Mount / Plate Gasket Mount / PCB Gasket Mount
- QMK/VIA Supported(wired)
- Support PCB stabilizers
- Unbuilt Weight
  With PVD WEIGHT: 1.693kg
  With Alu WEIGHT: 1.425kg
- Built Weight
  With PVD WEIGHT: 1.86kg
  With Alu WEIGHT: 1.592kg
We have adopted a three-in-one structural design for the internal structure, which can support regular positioning plate gaskets, PCB gaskets, and the long-disappeared TOP Mount structure.
Thanks to the consistent frame of the compact 75% layout, we can make the three structures perfectly compatible.
-TOP Mount
-Plate Gasket Mount
-PCB Gasket Mount
Case Colors Options:
-4 E-coat case: E-white, Milky White, Pink, Lilac
-6 Anodized Case: Orange, Black, Brown, Grey, Silver, Green
-7 color combose case:E-White&Black, Orange&Black, Grey&Black, Silver&Black, Wine Red&Black, Deep Blue&Black, Green&Black
Weight Options:
Designs:
- Blank Weight (Default)
- Cursive Text Weight (Add-on only)
Colors:
-4 Alu Weight: Gold/Silver/Black/Rose Gold
-6 PVD Weight: Gold/Silver/Black/Blue/Rose Gold/Chroma
PCB Options:
-Wired Flex Cut Hotswap PCB( 1.2mm, Multi Layout ,7u split spacebar, No Per-key RGB, support QMK and VIA )
-Wired Solder PCB / Wired Non-Flex Cut Hotswap (1.6mm, Multi Layout,7u split spacebar, No Per-key RGB, support QMK and VIA )
-Wired Per-Key RGB Hotswap PCB (Add-on only, 1.6mm, Non-Flex Cut, ANSI Layout, support QMK and VIA )
-Tri-mode ANSI+ISO Hotswap PCB (1.2mm, Non-Flex Cut, No Per-key RGB, support Mykeyclub Software)
Tri-mode ANSI Hotswap PCB upgraded to be compatible with ISO.
Noted: The Tri-mode technical support is provided by IRISLab. Really appreciate their support and help.
7 Plates are available
-Plateless
-Flex Cut Plates: FR4, ALU, Brass (Add-on only)
-Non-flex Cut Plates: PC, POM
-Alu and FR4 Half-plate (Add-on only)
Noted: We highly recommend using a PC/ POM/FR4 plate for Tri-mode PCB because the Brass and ALU plate will have a little affection for connectivity.
What's Included in MKC75?
- Full CNC Aluminum Top case *1
- Full CNC Aluminum Bottom case *1
- Weight(Anodized Alu Weight or Stainless steel PVD Weight) *1
- Internal Alu Weight (Only for the Tri-mode Version Case) *1
- PCB  *1
- Plateless or Plate  *1
- IXPE Foam *1
- Poron Case Foam *1
- Poron Plate  Foam *1
- Type-C Daughterboard with JST Cable *1
- PCB GAS Silicone Column *12
- Plate GAS Silicone Sock *18
- Top mount screw and spacer *12
- PCB stabilizers o-ring *12
- Footpad *6
- Poron case strip *6
- 1.6mm hex key *1
Gift(will not send make-up or replacements)
- 1 Pack of Extra Screw
  M2x3mm cylindrical head screw *2
  M2x8mm cylindrical head screw *2
  M3x12mm countersunk screw *2
  M3x6mm countersunk screw *2
- 2200mha battery (Only for the Tri-mode Version Case) *2
- Silicone pad of battery compartment (Only for the Tri-mode Version Case) *2
- Carry Case  *1
- MKC Stabilizer Set *1
MKC75 Review Links (Stay Tuned for More)
Content-------------Creator Prototype
Switch and Click-------------Green Case+Chroma PVD Weight
Hipyo Tech-------------Lilac Case+Chroma PVD Weight
Simulator Tech-------------Green Case+Gold PVD Weight
whnkeys - Soundtests-------------Green Case+Gold Alu Weight
Rx003-------------Pink Case+Rose Gold Alu Weight
KSJ KeeB-------------Silver&Black Case+Chroma PVD Weight
MechTech Keyboards-------------Deep Blue&Black Case+Blue PVD Weight
Captain Sterling (Prototype)-------------Orange Case+Black PVD Weight
승업키보드 SeungupKBD -------------Brown Case+Silver PVD Weight
apiarykeyboards -------------E-White Case+Chroma PVD Weight
Mykeyclub Team
We are a platform that integrates creativity and innovative design, helping more studios join this hobby community and bringing more fun and cool products to you guys.
Please participate in our MKC family for more discussions and future updates.
MKC75 IC Form
Mykeyclub discord
Mykeyclub Ins
Best Wishes
Mykeyclub Team
« Last Edit: Fri, 07 June 2024, 05:28:28 by Mykeyclub »
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Good News! The current sales DATA is very WELL, so our team has upgraded the packaging to a NICE Carrying Case for this pre-order, allowing everyone to use our keyboard anytime and anywhere.
Offline Xxyion
I'm really excited for this board!  I ordered 2.  One right at launch and the other yesterday.  Both are now coming with a carrying case?  That makes me even more excited.  I think this board will be one of my favorites for sure.
Offline HolySwitch
    • HolySwitch
Love the project!
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Yes,  both boards will now come with a carrying case. Thank you, I believe it will not let you down!
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Don't miss solid keyboard :thumb:
Offline alper_maestro
Does the tri-mode version include standard ; non-flex or flex cut pcb?
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Tri-mode version only has Non-Flex Cut.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Hi everyone! We are thrilled to announce that due to the sales meeting our expectations, our team has decided to include an additional bonus for this presale - the MKC Stabilizer Set. With just one week remaining until the PRE-ORDER end, don't miss out on this fantastic pre-order purchase and Bonus. ;)
Offline Xxyion
Glad to see the GB is going so well.  I'm very excited for this keyboard.  Will definitely be building it and reviewing it on my youtube channel.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Your excitement for the keyboard is truly appreciated. We can't wait to see your build and review on your YouTube channel!
Offline loki993
Is there somewhere I can go to research or read about the different PCBs and plates and how they affect the keyboard or can someone help me out with that?
Like why would someone want the flex cut PCB over the non?
I assume with the plates you use the flex cut plate with the flex cut PCB.
What do the different types of plates do?
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
For PCB and plate made from the same material, the flex cut and non-flex cut will affect the typing sound and typing feel. Typing sound with flexcut PCB might not be as resonant as that none flexcut PCB, yet the typing feel of the flex-cut PCB could be gentler and smoother. If the typing feel is your primary concern, choose the flex-cut PCB, and if sound quality is your main concern, then a non-flexcut PCB might be more suitable. However, if you consider both, we suggest selecting a flex-cut PCB, and you can mod the PCB to enhance the typing sound.
Here are the differences in typing sound and typing feel for different plates.
PC Plate:
Typing Sound: PC material typically produces a soft, crisp sound with subtle resonance.
Typing Feel: PC keyboards generally offer a lighter feel, and the key presses might feel more lightweight yet slightly elastic.
POM Plate:
Typing Sound: Keyboards made from POM material might generate a pronounced "sliding" sound, often with a deep and stable tone.
Typing Feel: POM keyboards offer a relatively smooth feel, with a slight gliding sensation in key presses and a sense of stability.
Aluminum Plate:
Typing Sound: Aluminum keyboards can produce a clear, solid sound with potential metallic resonance.
Typing Feel: Aluminum keyboards generally offer a solid feel, and key presses might feel tight with a sense of stability.
FR4 Plate:
Typing Sound: Keyboards with FR4 material usually produce a mellow sound without significant resonance.
Typing Feel: FR4 keyboards typically provide a moderate feel, where key presses might have some elasticity, but the overall feel is balanced.
Please note that the descriptions provided are general in nature. Various factors, including keycaps, cutout designs, spring types, and more, influence actual sound and feel. The best choice depends on personal preferences, so if possible, it's recommended to try different keyboard materials to find the one that suits you best. You can also check with the review the video to check more details.
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Hi everyone! We're excited to inform you that the MKC75 is currently available for in-stock sales. If you missed it during our previous pre-order, don't miss out this time!
