Author Topic: [IC] KAM Illusion  (Read 4157 times)
Offline Scucka
[IC] KAM Illusion
« on: Sat, 05 August 2023, 16:43:46 »
Hello, everybody!
Step into our new illusion themed project designed by Lollipop and me!
Initially the set looked entirely different and had various visions in our minds and it was a constant change after change regarding different methods of achieving illusionary themed keycaps.
To design the legends of KAM Illusion we took inspiration from Illusory Contours. "Illusory contours" are imaginary lines or shapes that we perceive in our minds, even though they don't actually exist in reality. Our brains create these contours when presented with certain patterns or arrangements of objects, making us see edges and shapes that are not physically present. As for the novelties, different types of optical illusion were used to get the confusion when looking at them. Is it 3 or 4 columns? Why does lines begin to move around? We used this concept carefully as not to completely ruin the theme.
Please note: Due to different lighting setups and camera settings the images may differ on different monitors from what they look like in real life.
We do not have professional studio equipment to perfectly depict the irl keycaps.
From our personal opinion, we are happy enough with how they ended up and we can assure that the final result will be even better.
Keycap Details
KAM profile is a profile originated from R2 KAT, quite flat similar to DSA
TBD
TBD
TBD
Special thanks to Blamby for making the renders for this project!
Signature
If you want to support the set please consider adding this signature to your profile!
Code: [Select]
[url=https://geekhack.org/index.php?topic=121041.0][img]https://i.imgur.com/UEgLpG3.png[/img][/url]
« Last Edit: Sat, 05 August 2023, 17:24:36 by Scucka »
Offline DontStealMyLolipop
Re: [IC] KAM Illusion
« Reply #1 on: Sat, 05 August 2023, 16:44:26 »
Reserved
