Author Topic: [IC]Snow grape switch  (Read 5535 times)
Offline moyu.studio
« on: Tue, 15 August 2023, 02:42:49 »
Hello, this is Moyu.studio
This time, we bring the Snow Grape Switch, jointly launched with Oriental Switch Collector XCJZ(XCJZ is a renowned switch collector in the East, and his LUCY switches are quite popular in both Eastern and Western communities).
The Snow Grape Switch was jointly designed by XCJZ and Moyu.studio and manufactured by Wikuo, a subsidiary of Moyu.studio
301570-0
Snow Grape switch Specifications:
- Linear
- 58g spring(18mm)
- POM Lengthen stem
- Custom milk Blend top housing
- Mixed nylon bottom housing
- 5 pin
- 3.8mm Travel
- Made by Wikuo
- Mild lubrication
301572-1
We have used the latest micro lubrication scheme on the Snow Grape switch. According to the characteristics of the mold, only slight lubrication is applied to the areas where the stem and leaves come into contact, which can ensure a smooth feeling and no noise during pressing
This is the characteristic of the Snow Grape Switch: stable, smooth, no noise, dry, and ready to use after opening the box.
301574-2
Q&A
Q:What is Wikuo?
A:Wikuo is a sub brand we founded in early 23, using our own molds. The original intention of the Wikuo brand is to provide designers with comprehensive support in switch manufacturing, rendering, and sales channels. Currently, it has served multiple designers.
Q:Will the Snow Grape Switch be a group buy?
A:No, we hope to use spot sales, which is more user-friendly for consumers and can get the switch in a shorter time. But correspondingly, we need longer time to prepare.
Q:Is this a new mold?
A:Yes, this is our new mold. We have made some changes to the mold for the dustproof stem, adding some reinforcing ribs to the top shell of the switch. No matter what angle you press, the snow grape switch can ensure a smooth feeling and become more stable.
301576-3
Vendor List:
« Last Edit: Mon, 04 September 2023, 20:28:10 by moyu.studio »
Offline Horu
Re: [IC]Snow grape switch
« Reply #1 on: Thu, 17 August 2023, 00:11:23 »
Moyu studio and XCJZ, very excited.
Glwic!
Offline moyu.studio
« Reply #2 on: Tue, 22 August 2023, 20:02:31 »
Glwic!
Thank you!
