Author Topic: [GB] LM75 - 75% by LM - rubber ball/tadpole mount - Cancelled  (Read 37817 times)
Offline daviddgm
« on: Wed, 16 August 2023, 07:08:43 »
A 75% with exploded/lowered arrow keys of LM series
Highlight points
- Clean and beautiful design approved on the LM60 V2 model
- Silicone Rubber Ball/Geon's tadpole mount
- RGB light pass-through hole (optional)
- Many color options
- Front angle top available
- PCB with ISO and split space bar support
- Extra plates and top available
- Different colors for top and bottom (optional)
Please check others colors on Instagram or order link bellow.
https://www.instagram.com/p/Cvzr4QmMn2f
Our last keyboard project LM60 V2, that influenced and is design base of LM75
Mount type
Tadpole from Geonworks (will be included)
Mount Shock Absorption Balls - used in drones (will be included)
Alternatively It can be top mounted using 8x M3 screws.
Layout options
Details
Top Aluminum
Bottom Aluminum
Side RGB led light through Polycarbonate (no RGB available)
Case Angle: 6.5 degrees
Mounting: Rubber Shock Absorption Balls or Silicone Tadpole from Geonworks
Case Material: 6063 aluminum
Making process: CNC - sandblast - anodizing
Front Height: 19 mm
Back Height: 21 mm (with chamfer) and 32 mm (before chamfer)
Weight: ~1400g and ~1800g (mounted with brass plate)
Plate:  Aluminum, Brass, FR4 (POM on demand)
PCB Compability: Customized PCB from Y & R Studio or ID80 V2
What will be included
- LM75 Top
- LM75 Bottom
- Plate
- Stainless screws
- Silicone Rubber Mounts (Mount Shock Absorption Balls)
- Tadpole from geonworks (if MOQ 40 sets sold)
- Silicone Rubber feets
- Polycarbonate inserts for the RGB holes
- Customized PCB
Timeline and fulfillment date
August: 16-30 Group Buy
September-October (first half): Production
October-November: Shipment (Will be available: Aliexpress forwarding, Fedex/DHL and Germany forwarding to EU).
Price
One set USD 195.00 (USD 145 for ID80 V2 layout - PCB not included)
Two sets USD 320.00
Thee sets USD 440.00
Prices including hotswap PCB (for more than 40 sets sold, we can offer extra solder PCB by USD 30)
Extra plate from USD 25.00
Order Link
https://www.dgmelet.com/opencart/index.php?route=product/product&path=68&product_id=565
https://www.dgmelet.com/opencart/index.php?route=product/product&path=68&product_id=568 (ID80 V2 layout version - PCB not included)
(For two and three sets - contact us for color and options)
https://www.dgmelet.com/opencart/index.php?route=product/product&path=68&product_id=566
https://www.dgmelet.com/opencart/index.php?route=product/product&path=68&product_id=567
The second order option: Pay 30% in advance (PayPal) and others 70% more shipping by Aliexpress link when your LM60 V2 is done, before shipment.
Regards,
Eng. David Martinz - LM Keyboards
daviddgm at gmail
Instagram @lm_kbd
« Last Edit: Fri, 13 October 2023, 16:52:15 by daviddgm »
Re: [GB] LM75 - 75% by LM - rubber ball/tadpole mount
« Reply #1 on: Wed, 16 August 2023, 12:40:15 »
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
Offline alper_maestro
« Reply #2 on: Thu, 17 August 2023, 09:16:49 »
Can we see the Red color in real? There is non on the website.
are there completed prototypes that have been tested and are there videos of them? I only see renders above.
where is the rgb part? I can't find that based on the photos? Or is that the part on the side?
Offline daviddgm
« Reply #3 on: Thu, 17 August 2023, 11:56:51 »
Hi! We have added red rendered image on the site. The LM75 is a 75% reproduction of LM60 V2 that was fully tested. For the LM75 we can  guarantee that more tests and verifications will be made when the production begin.
These videos are for LM60 V2.
« Last Edit: Sun, 27 August 2023, 09:16:46 by daviddgm »
Offline daviddgm
« Reply #4 on: Mon, 04 September 2023, 08:00:27 »
LM75 to use with popular ID80 V2 PCB will be available by USD 145 (PCB not included) from Sep-04 to Sep-08.
« Last Edit: Mon, 04 September 2023, 10:45:07 by daviddgm »
Offline godofdeath
« Reply #5 on: Mon, 04 September 2023, 15:48:36 »
Nooooo. I missed this, I was on vacation.
Any way to get an order in?
Offline daviddgm
« Reply #6 on: Mon, 04 September 2023, 16:18:48 »
Yess...
Offline godofdeath
« Reply #7 on: Mon, 04 September 2023, 17:38:46 »
It says LM70 Color, is that the color options for LM75? Just wanted to make sure
And how can I order more plates? I would like to get one of each
« Last Edit: Mon, 04 September 2023, 17:51:54 by godofdeath »
Offline daviddgm
« Reply #8 on: Mon, 04 September 2023, 18:57:06 »
Color title was corrected and we added option for 3 extra plates.
Offline ELE.WORKS
« Reply #9 on: Tue, 05 September 2023, 05:29:34 »
It feels a little ordinary
Offline godofdeath
Re: [GB] LM75 - 75% by LM - rubber ball/tadpole mount USD145+
« Reply #10 on: Tue, 12 September 2023, 19:17:20 »
How do you get a receipt for your order? I don't have anything showing up in my email.
Offline daviddgm
« Reply #11 on: Wed, 13 September 2023, 19:29:31 »
Hi! We are sad to inform that Group Buy was cancelled because the MOQ was not met. Sorry and thank you for your support
and trust.
Offline godofdeath
« Reply #12 on: Thu, 14 September 2023, 20:09:06 »
noooooooo :'(
