Author Topic: [IC]Keygeek Muguet Rose Switches  (Read 3662 times)
Offline Aregs Keyboard
« on: Mon, 21 August 2023, 09:06:52 »
Hello! Here is NLandkeys, I'm Aregs.
301851-0301853-1301855-2301857-3
Inspiration
This switch is a switch designed by a friend of mine, who is also the designer of Keygeek xiaoxin switches, which is the first keygeek customized switch in China.
The inspiration for designing the Muguet Rose switch came from seeing pink lily of the valley flowers when he was playing in the Nanjing Botanical Garden in May this year. In his previous knowledge, lily of the valley flowers are mainly white, until he saw the pink translucent color in the Botanical Garden, which was very stunning, and he wondered if he could make a switch with the same color scheme.
The pink lily of the valley is called Muguet Rose in French, so this switch came out of it.
Spec:
Linear
R1 Housing
U2 Stem
Total travel 3.8 mm
Pre-travel 2.0mm
Bottom force 48g
Double-stage 21mm spring
5PINS
Pre-lubed
Manu:Keygeek
Material
-What is R1 Material?
-R1 is a material made of modified PC with some additives, it has a high degree of smoothness even with a fully transparent appearance, they are amazing
Form of Sales
Pre-Order
Price: $5.5/10pcs
Date:8/25--9/20
EST:10/15--10/20
Vendor List:
Global:NLandkeys:https://nlandkeys.com/products/coming-soon-keygeek-muguet-rose-switches
Others:TBD
Our discord:https://discord.gg/3zeEu5mxBn
Video:
https://www.bilibili.com/video/BV1KN41187Ns/?spm_id_from=888.80997.embed_other.whitelist&t=1
301859-4301861-5301863-6301865-7
« Last Edit: Mon, 21 August 2023, 09:09:08 by Aregs Keyboard »
