Author Topic: [Pre-order]Real DIAMOND Shape Switches??--Diamond Avalon  (Read 23700 times)
Offline Aregs Keyboard
« on: Mon, 21 August 2023, 10:39:35 »
Hello! Here is NLandkeys, I'm Aregs.
301869-0301871-1301873-2301883-3
PS:Photo taken by Alexotos
Inspiration
Yes, as you can see, these switches are different from the traditional MX structure and appearance, the mold has been redesigned, they are real diamond shape, Top, Stem using the "diamond shape" shape design, the top surface is completely symmetrical, surrounded by a triangular diamond facets, sharp edges, to highlight the sharp look and feel!
Back to Switch
Smoothness: In the case of the diamond switches factory lubricated only the leaf of the springs, the press feel very smooth
Feeling of the bottom: very clean feeling, is my type
Noise: thanks to from Japan materials and springs, combined with high-precision molds, in the factory only slightly lubricated switch leaf, the noise control is very good, almost no noise after upgrading the test (unless your ear is almost close to the shaft to listen to)
Keycap compatibility: No any compatibility issues
301878-4301881-5
SEPC:
Linear
Blended Nylon Housing
POM Stem
Total travel 3.8 mm
Pre-travel 2.0mm
bottom force 58g
Single-stage spring
5PINS
Light Pre-lubed
Sound Test and reviews:
Alexotos will streams them this week!'
Price and Sales Form
Price:$0.69/pcs
We will start a small 5 day pre-order on 8/24, they are in the final steps of production and will be all finished within the month of August!
Pre-order Qty: only 15K
Pre-Order EST: 9/5
Global Vendor: NLandkeys https://nlandkeys.com/products/diamond-avolon-switches
« Last Edit: Sun, 03 September 2023, 02:51:39 by Aregs Keyboard »
Offline Raenbo
  • IG: @aero_keys
Re: [Pre-order]Real DIAMOND Shape Switches??--Diamond Avalon
« Reply #1 on: Tue, 22 August 2023, 09:56:55 »
Artisan switches!!
