Author Topic: Pics of my new boards (IBM SS, Ortek MKB-84, NMB Space Invader)  (Read 9669 times)
Offline MissileMike
« on: Wed, 13 October 2010, 13:50:04 »
I went to a medical supply place and got these three boards for ~100$
First up, the Model M Mini.  It was a terminal board, but I had an extra 1391401 controller that swapped in beautifully.  The board is absolutely mint!  Check out the caps, are these strange ones?
Next up is the Ortek MKB-84.  Also in terrific shape- uses simplified white alps from what I can tell.  It feels great to type on.
Last a space invader nmb board: RT8756C+.  Great switch, similar to cherry blues:
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline CeeSA
« Reply #1 on: Wed, 13 October 2010, 13:54:22 »
the Ortek MKB-84 looks superb! congrats
Offline WhiteRice
« Reply #2 on: Wed, 13 October 2010, 14:10:14 »
Nice haul! Looks like you got  a NIB M SSK anyway ;)
Offline MissileMike
« Reply #3 on: Wed, 13 October 2010, 14:30:37 »
Thanks.  Yep, if it was ever used, it sure wasn't used much.
Mods can you move this to the pics forum please?  Sorry I posted this in the wrong place.
Offline elservo
« Reply #4 on: Wed, 13 October 2010, 14:47:42 »
Glossy keys normal for the minis?  Great pics!
Majestouch Tactile Click (Work)
AEKII(Home)
Offline itlnstln
« Reply #5 on: Wed, 13 October 2010, 15:04:56 »
Just the sides.  The tops are matte...
Offline jpc
« Reply #6 on: Wed, 13 October 2010, 16:07:12 »
Wait what? You can use a 1391401 controller in an SSK?
Are the membranes really that similar?
I'll need to photograph some SSK membranes next time I have one of them opened up, and compare against 1391401 membranes....
RSI prevention recipe:[/B] Kinesis Contoured, Colemak layout, touch typing, Contour Design Rollermouse,  Logitech TrackMan Wheel, Logitech m570 trackball, "workrave" break timer software, "awesome" window manager, tenkeyless boards, cherry browns, Wang 724 with "ghetto green" ALPS, standing desk and/or comfy adjustable chairs, stress reduction, computer time reduction.
Fun non-ergonomic things: bolt modded Model M Space Saving Keyboards with new springs, Kensington Expert Mouse v7, Unicomp Endurapro, Northgates
Offline itlnstln
« Reply #7 on: Wed, 13 October 2010, 16:11:22 »
I don't think it needs to be all that similar, it just depends how they routed the traces.  That said, I think there are some SSK key combos (like Num Lock) that might need a specific controller to handle them.
Offline MissileMike
« Reply #8 on: Wed, 13 October 2010, 16:18:56 »
It works... The membrane cable on the left fits perfectly, and then the one on the right just needs to be flush to the left side.
Offline jpc
« Reply #9 on: Wed, 13 October 2010, 16:35:56 »
Quote from: MissileMike;233431
That's awesome! Does every key work?
Could you post a pic and maybe include the P/N of the controller you used?
This could make terminal minis valuable. If they're valuable, they'll come out of the woodwork and onto ebay...
"YOU get an SSK!
YOU get an SSK!
EVERYBODY gets an SSK!"
Offline MissileMike
« Reply #10 on: Wed, 13 October 2010, 16:41:01 »
Every key works, but I didn't test the alternate numpad.  How do I enable that on an m spacesaver?
Quote from: jpc;233439
"YOU get an SSK!
YOU get an SSK!
Offline jpc
« Reply #11 on: Wed, 13 October 2010, 17:07:01 »
The alternate numpad doesn't appear to be built into hardware, AFAICT. It's a driver thing.
Offline jpc
« Reply #12 on: Wed, 13 October 2010, 17:10:10 »
Here's a data point. I compared membranes from a 1987 1391401 and a 1996 71G4644.
They have compatible trace patterns.
(That is not to say that these membranes are interchangeable. The 71G4644 is rubber dome, and its contacts are directly below the centers of the keys. On the buckling spring board, the contacts are offset maybe 2mm from center.)
But, from the controller's point of view, they look identical.
Next step is to compare this to a mini's trace pattern.
Offline MissileMike
« Reply #13 on: Wed, 13 October 2010, 17:11:52 »
Yes, seems that way.  That part does not work, but I confirmed with aquakeytest that every key does work.  Will post pics soon.  Need to find time to re-open it up.
Offline TexasFlood
« Reply #14 on: Wed, 13 October 2010, 17:26:57 »
Those keyboards are terrible.  I volunteer to take them off of your hands so you don't have to bear the pain of dealing with them.  :wink:
Honestly, very nice, congrats.  I was going to say "throw them on the stack" but you might actually want to keep these on the desk, at least for a while.
Offline MissileMike
« Reply #15 on: Wed, 13 October 2010, 17:32:04 »
I used the space invader board all day today- those are under-rated switches around here.
It looks like someone had the ortek before me, there is a thread about it from last year.
http://geekhack.org/showthread.php?t=6025
Offline jpc
« Reply #16 on: Wed, 13 October 2010, 17:48:08 »
Holy smoke, I'm typing this on an SSK (a 1391472 born on 9/11/87) using the controller out of a junked 71G4644 from 1996.
Just like MissileMike said, I left-adjusted the smaller membrane tab. And voila, the best Model M works with the controller from the worst Model M.
The 71G4644 has the same membrane pattern as a 1391401 from 1987. So it seems likely that many SSKs can work with many full-size Model M controllers.
Offline EverythingIBM
« Reply #17 on: Wed, 13 October 2010, 18:13:05 »
Quote from: itlnstln;233376
I didn't know Shawn Stanford had a brother. =p
The brat prince of DOS... or something.
Offline jpc
« Reply #18 on: Wed, 13 October 2010, 18:22:26 »
Amazing. Every terminal SSK can be made to work. Every non-responsive SSK can be made to work.
Pics.
The controller in the background is the original controller from this 1391472 SSK which works but its SDL connector is loose like a kid's tooth. One tug on the cable could uproot the connector and a few PCB traces too. (That controller is another gem from ebay. I didn't know Model Ms could be in such bad shape until I bought some "nice shape" examples on ebay.) What a relief to have an alternate controller!   :^D
The 71G4644 controller is mechanically compatible with the original. It's the same width, right about 2". It has the connector at the same location; and the two holes below the connector are the same size and location. The 71G4644 controller uses a plastic "guillotine" to hold the non-removable cord in place, and (to my surprise) this is perfectly compatible with the SSK's case.
Interchangeable parts FTMFW!
Offline MissileMike
« Reply #19 on: Wed, 13 October 2010, 18:41:22 »
The 52G controller also works, btw.  I tried both.  Kishy said he suspected his was this way already, and there was actually a thread a while back saying a controller swap would work.  That's why I bought it in the first place.
Anyway, the one caveat is that the shift-scrolllock numpad will not work using a full-size m controller.  (But who really cares)
Offline jpc
« Reply #20 on: Wed, 13 October 2010, 23:05:27 »
I'm thrilled at how interchangeable these controllers are. I could have sworn I remembered a thread in which top geekhack minds ruled out swapping a full size controller into an SSK. Can't find it now though. Maybe I dreamt it.
I do dream about geekhack now. Yeah it's bad.
Thanks MissileMike. This is a great new development!
