Author Topic: [IC] DCD Flower Journal - A Botanical Classic  (Read 32823 times)
Offline mariajose1197
« on: Fri, 25 August 2023, 12:46:16 »
Introducing my first creation in collaboration with MrBingo:  ''DCD Flower Journal'' Immerse yourself in the nostalgic charm of vintage botanical books every time you type. Designed to capture the elegance of classic botanical illustrations, these keycaps bring a touch of nature's beauty to your keyboard.
Real Photo by DROP
MAN60 by Geon Works
8XMK2 By KBDfans
Still to be Confirmed
CASE
6° Update
Confirmed Preorder Date and Photos:
5° Update
Correction and Approval of Pantone in the Samples:
4° Update
Checking Samples with Pantone:
3° Update
Keycaps Samples:
3° Update
Pantone Samples:
2° Update
Manufacturing:
We decided to go for DCD, which is PBT single shot with dye sub legends.
1° Update
Manufacturing:
We have two options.
1-Dobleshot with UV
2-PBT dye sub
We are currently very inclined to go with PBT dye sub. We are going to be reaching out to different manufacturers and make a decision based on that.
Colors: We have used the pantone guide book and we are ordering the phisical plastic chips and once we get them. It will be added to the post.
If you want to do a collaboration, send me a DM on Instagram or Discord
Interest Check!
Global:
08/25/2023: IC Online
10/10/2023: Contract with DROP
10/10/2023: Manufacturing
09/17/2024: Pantone Samples
10/24/2024: Keycaps Sample
10/25/2024: Samples Arrival
10/27/2024: Checking Samples with Pantone
11/13/2024: Correction and Approval of Pantone in the Samples
11/19/2024: Planned Preorder
11/30/2024: Photos
12/04/2024: Preorder!!!
Thanks to Arq for the advice and MrBingo for the support, advice to make this set and your friendship.
To Skyler for the support, love and encouragement when I didn't think the set would get to where today. ♥
And to the talented Angel Maya
for bringing this idea to life.
If you want to support this project, add the signature below to your profile:
Thank You!
Code: [Select]
[url=https://geekhack.org/index.php?topic=121255.0][img]https://i.imgur.com/YVhA1yH.png[/img][/url]
« Last Edit: Fri, 06 December 2024, 15:16:31 by mariajose1197 »
Offline MrBingo
Re: [IC] Flower Journal - A Botanical Classic
« Reply #1 on: Fri, 25 August 2023, 12:46:53 »
Reserved!
Offline dededecline
    • Linktree
« Reply #2 on: Fri, 25 August 2023, 13:14:14 »
Cool set! I would suggest adding some details about manufacturing though - I imagine this is dyesub? Any idea who the manu will be? Color codes?
Also you have two R2 1.5u pipe keys, you can remove one.
Offline ankit
  • Formerly ankit-sachdeva
Re: [IC] GMK Flower Journal - A Botanical Classic
« Reply #3 on: Fri, 25 August 2023, 13:15:24 »
Also 2x R4 1u Fn
Would suggest 1.5 "Backspace" legend instead of "<- Back" as well.
Offline TyPo.mk
« Reply #4 on: Fri, 25 August 2023, 13:35:47 »
This is fun but I think it should just be dyesub instead of GMK. GMK uv printing can slightly stretch and drift during printing and I think it would be especially noticeable on the fine details of this set.
I also think adding numpad “subs” would make the set look more balanced on a full sized board
GLWIC!!
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #5 on: Fri, 25 August 2023, 13:54:33 »
Also gmk uv printing is far more faded colour wise than the doubleshot colouring so the colours won't match if you are trying to do that (which seems like are) I remember someone showing me gmk hooty in person at the melbourne meetup and the sublegend did not look the accent colourwise.
I agree that regular dye sub (or maybe even a tripleshot manu if they can do that) might be a better alternative. GLWIC
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline dededecline
    • Linktree
« Reply #6 on: Fri, 25 August 2023, 13:57:30 »
Those sublegend designs definitely don't meet doubleshot/tripleshot tolerances, it'd need to be UV print or dye-sub
Offline Rhienfo
« Reply #7 on: Fri, 25 August 2023, 14:55:32 »
Yeah I had a feeling that it would be too complicated to work but still put the idea anyway, don't know too much about keycap tolerances and such to know 100% that cause I've never really looked into it. Then dye sub will be the best option personally.
Thanks for telling me/thread :)
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline shendoo
  • *RAUGHS*
« Reply #8 on: Fri, 25 August 2023, 15:49:28 »
Great thematic! I'll be keeping an eye out! GLWIC!
Offline MrBingo
« Reply #9 on: Fri, 25 August 2023, 17:36:55 »
hello, we have updated the Manu and the colors, and thank you for spot de double pipe key, I hadn't noticed!
Offline MrBingo
« Reply #10 on: Fri, 25 August 2023, 17:38:30 »
Also 2x R4 1u Fn
thanks I hadn't noticed about the FN key, and the 1.5 backspace key, we will take it into consideration, thanks!
Re: [IC] PBT Flower Journal - A Botanical Classic
« Reply #11 on: Fri, 25 August 2023, 17:40:04 »
Thank you to the people so far who have showed their appreciation for the set.
We have two options for the set:
Dobleshot with UV
PBT dye sub
We are making  the kitting changes that have been suggested.
Thanks all!
« Last Edit: Fri, 25 August 2023, 17:44:44 by mariajose1197 »
« Reply #12 on: Fri, 25 August 2023, 17:43:41 »
GLWIC!!
hello! taking into consideration all the other people's comments we are inclined to do it pbt dyesub, and thanks for the numpad idea, we will see what we can do, thanks!
« Reply #13 on: Fri, 25 August 2023, 17:44:07 »
Thanks!!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #14 on: Fri, 25 August 2023, 19:53:38 »
GLWIC!!
title changed = "Re: [IC] GMK Flower Journal - A Botanical Classic"
Does GMK do PBT dyesub?
Offline juliday
  • Synth, Controller, and Keyboard
    • SagakLabs
« Reply #15 on: Fri, 25 August 2023, 21:52:28 »
Nice set!
not to mension, very unique.
Offline stidal
  • milo#3939
« Reply #16 on: Sat, 26 August 2023, 10:31:00 »
super super cute. looking forward to more manufacturer info :]
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline vhaarr
« Reply #17 on: Sat, 26 August 2023, 11:06:03 »
Please stay away from enjoyPBT/ePBT at least. I only have one set from them and it's not good. Perhaps they have improved since, but I wouldn't know.
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
« Reply #18 on: Tue, 29 August 2023, 14:50:19 »
Nice set!
Thaks!!! :D
« Reply #19 on: Tue, 29 August 2023, 14:52:51 »
I hope to have more manufacturer info soon!!!  ;)
« Reply #20 on: Tue, 29 August 2023, 14:55:06 »
I'll keep eye on that!  :)
Offline EdgeOfInfinity
« Reply #21 on: Thu, 31 August 2023, 14:44:13 »
i think this is a very strong concept, looking forward to seeing samples. dye-sub is prob going to be the best execution in this case i would think
Offline lkkedward
« Reply #22 on: Fri, 01 September 2023, 04:03:18 »
any color codes
Offline roffelsaur
« Reply #23 on: Sat, 02 September 2023, 01:34:37 »
Wood look good with a good wood board <3
Offline etelazel
« Reply #24 on: Tue, 26 March 2024, 07:50:07 »
Introducing my first creation in collaboration with MrBingo: ''PBT Flower Journal'' Immerse yourself in the nostalgic charm of vintage botanical books every time you type. Designed to capture the elegance of classic botanical illustrations, these keycaps bring a touch of nature's beauty to your keyboard.
[/color]
Awesome :thumb: It seems to me that doubleshot in this case will hold up better and look better over time. And I love this bow, connecting with nature is always a plus. It would go very well with my small library and eco-style room.
I like having paper books, even though they didn't help me write my personal statement for college. I used https://edubirdie.com/personal-statement-writing-service that time. I found the perfect balance for my spirit and mind.
« Last Edit: Sun, 31 March 2024, 08:32:19 by etelazel »
Offline Alvi
« Reply #25 on: Fri, 29 March 2024, 08:21:10 »
This looks really nice. I'd have a preference for doubleshot as well. Lovely design!
« Reply #26 on: Tue, 09 April 2024, 15:50:17 »
doubleshot means the (very detailed) subs will be UV printed, potentially more likely to rub off over time.
Offline dvorcol
« Reply #27 on: Fri, 02 August 2024, 16:05:17 »
Is the plan now for Drop to run this this in DCD this October?
Offline CrlaoSvloadr
« Reply #28 on: Wed, 07 August 2024, 18:39:35 »
Huge fan of the overall theme, can't wait to see more updates and collabs!
Offline arq1999
Re: [IC] DCD Flower Journal - A Botanical Classic
« Reply #29 on: Sat, 16 November 2024, 20:14:44 »
Looks good! Can't wait
« Reply #30 on: Sat, 16 November 2024, 21:32:51 »
DROP sent me this photo and it looks much better than the samples they sent me in October
« Reply #31 on: Mon, 18 November 2024, 07:41:46 »
Wey already confirm a collab with YVK Studio
« Reply #32 on: Mon, 18 November 2024, 07:44:22 »
Yes, but there were some problems with the brown color and it has been running a little late.
« Reply #33 on: Mon, 02 December 2024, 22:07:55 »
The legends have been modified and the pre-sale has been confirmed for December 4th
Here is a photo that I took in my garden
Offline SpookieBoogie
« Reply #34 on: Wed, 04 December 2024, 17:05:14 »
Was this still going on Drop today? Been looking forward to this one for a while
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
« Reply #35 on: Wed, 04 December 2024, 17:23:32 »
Currently live for pre-orders!
Great work, Maria and Bingo! I'm happy to see this set finally be available
Edit for link: https://drop.com/buy/drop-mr-bingo-dcd-flower-journal-keycap-set
« Reply #36 on: Wed, 04 December 2024, 19:34:17 »
The preorder link has already been updated.
Thank you very much for your support, we hope that the preorder is a success and you can have that set on your keyboards.
Offline Ammonite
« Reply #37 on: Thu, 05 December 2024, 01:47:02 »
Thanks for sharing the link. Just so you’re aware, the set isn’t appearing in the Mechanical Keyboards section on Drop, so it’s not possible to find it.
Offline dvorcol
« Reply #38 on: Thu, 05 December 2024, 17:11:04 »
You can find it in "Newest" on Drop's home page.
Or set filters to Mechanical Keyboards/Keycaps, although it is pretty far down that list. The "sort by:" filter comes up set to "Recommended". Change it to "Newest" and it's the 8th on the list.
Or just search for "Flower".
I have to say, though, that the organization of Drop's site leaves much to be desired.
« Reply #39 on: Thu, 05 December 2024, 20:16:27 »
Thanks for sharing this information!
The important thing is that you like the set and with this you can find it more easily ^^
Offline Ammonite
« Reply #40 on: Fri, 06 December 2024, 01:48:22 »
Thank you. It wasn’t there when I posted here but is now showing. I guess it takes a little time for their category page to update (no idea why but like you said their site leaves much to be desired!).
« Reply #41 on: Fri, 06 December 2024, 15:19:44 »
How great that it appears to you now ^^
« Last Edit: Sun, 08 December 2024, 14:17:15 by mariajose1197 »
« Reply #42 on: Sun, 08 December 2024, 14:19:42 »
Drop has discount on the preorder of the set ^^
Offline dvorcol
« Reply #43 on: Sat, 08 March 2025, 22:42:31 »
Drop now has kits in stock.
