Author Topic: [GB] Treasure TYPE-30 | 30% Ortho - The Smallest Keyboard  (Read 19286 times)
Offline Treasure
  • Industrial Designer / Inventor / Maker
    • Design & Eng
« on: Sun, 27 August 2023, 14:18:45 »
Treasure TYPE-30 |  30% Ortho Keyboard / Macropad
Interest check : https://geekhack.org/index.php?topic=118657.msg3144165#msg3144165
THIS IS A PRE-ORDER ( Group Buy )
Group Buy Opens: August 25th, 2023 @ 08:00 PM CEST ( Duration: 1 month ) Estimated Ship Date: Q2 2024
TYPE-30 is the new ultra-compact ortholinear keyboard by Treasure®
Perfect to be used as a large macropad, a compact mechanical dedicated keyboard, or an artisan display
Design-wise, Treasure TYPE-30 keeps the same design language as our beloved TYPE-9 macropad, with a classic and statutory feel.
TYPE-30 is a nomad, distraction-free companion that can fit in any bag
Dedicated custom layout for full grid or 2U space/enter
Dimensions: 238 x 69 x 20 mm ( Without keycaps )
Early Bird Pricing :
Aluminum Ver. : $199
Full Brass Special Edition: $319
Standard Pricing
Aluminum Ver. : $209
Full Brass Special Edition: $339
Features
Features
   Crafted from Aluminum 6061 or Solid Brass
   USB-C interface
   In-Switch RGB LED
   PCB compatible with QMK firmware / VIA / VIAL
   Low Profile custom silicone pads with 3M adhesive
   Tray mount with dedicated plate
Layout
   Option 1: Hot-swap PCB with a fixed layout
   Option 2: Solderable PCB with 2U enter and 2U space options for more flexibility
Keyboard Layout ( With 2U Spacebar ) :
Finishes
   Aluminum Finishes - Same as the current TYPE-9 Macropad group-buy
      White ( E-Coating )
      Black
      Purple
      Green
   Special Editions
      Full Brass finish ( Black Mirror )
The final product and colors can be slightly different from the pictures
Keycaps shown in the renders are for presentation only and are not sold with the keyboard.
Yes, But where is the spacebar?
1 : There is an "invisible spacebar" by the use of the QMK Combo feature.
You hit "space" with your thumb by hitting both 'B' and 'V' keys at the same time ( So the location of where the space bar would be )
One of the advantage of combos is that it allows you to keep the same alpha layout as a standard keyboard and does not change your muscle memory.
You can also have a clicky key-switch on either 'B' or 'V' to have a sound and/or sensory feedback each time you hit the "invisible spacebar"
2 : 2U space bar on the bottom row is also possible with the solderable layout.
Add Ons & Other Info
Following add ons are planned for the TYPE-30 :
   TYPE-30 DSA Line set ( Same set as TYPE-9 III, only there are 36 keycaps ) : https://treasuretypes.com/products/type-9-dsa-keycap-set
   TREASURE Standard Feet ( Available in 10 colors to personalize your keyboard ) : https://treasuretypes.com/collections/frontpage/products/type-9-feets-extra
   Extra TYPE-30 Plate
   Extra TYPE-30 PCB
PRE-ORDER NOW
« Last Edit: Mon, 28 August 2023, 14:59:35 by Treasure »
Re: [GB] Treasure TYPE-30 | 30% Ortho Keyboard / Macropad
« Reply #1 on: Mon, 28 August 2023, 10:00:49 »
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
Offline Treasure
    • Design & Eng
« Reply #2 on: Mon, 28 August 2023, 10:57:12 »
Thanks !
Offline Treasure
    • Design & Eng
Re: [GB] Treasure TYPE-30 | 30% Ortho - The Smallest Keyboard
« Reply #3 on: Tue, 29 August 2023, 10:54:34 »
Reserved.
Offline juliday
  • Synth, Controller, and Keyboard
    • SagakLabs
« Reply #4 on: Tue, 29 August 2023, 20:30:40 »
This one's absolutely cute!
Offline Treasure
    • Design & Eng
« Reply #5 on: Sat, 02 September 2023, 04:13:13 »
Hey Thanks !
Offline Treasure
    • Design & Eng
« Reply #6 on: Sat, 02 September 2023, 04:18:20 »
Short Video of the E-White Model :
Offline Treasure
    • Design & Eng
« Reply #7 on: Thu, 21 September 2023, 07:04:39 »
Last week to pre-order !
Pre-orders open until September 25th
