Author Topic: [GB]Cupid65 - Start from September 5th  (Read 95540 times)
Offline CHAOSERA
    • official website of chaosera
« on: Wed, 30 August 2023, 09:02:22 »
Hello everyone, we are CHAOSERA
After months, Cupid65 is about to go on group buy!
For us, the research and development of a product is like a long journey, with exciting and happy moments along the way, and of course, there are also some difficult days. All these come together to shape us today.
Fortunately, there has always been a group of friends supporting us all the way. This is our biggest motivation and greatest encouragement.
So, without further ado, here is Cupid65 for everyone!
1.Surface Treatment and Color Matching
As we mentioned before, Cupid65 included 3 different surface treatments, 11 colors.
Check our IC post here for more information: https://geekhack.org/index.php?topic=120312.msg3165704#msg3165704
Anodizing:
Moonlight silver
Heartseeker
Lavender Purple
Deep Ocean Blue
Agate Green
Electrophoresis:
Strawberry Milkshake Pink
Minty Seabreeze
Almond white
Cupid65-Hyacinthus edition
Powder coating:
Grapefruit Soda Orange
Banana Milkshake Yellow
2.Internal Structure
You could also find more detailed information in our IC post:https://geekhack.org/index.php?topic=120312.msg3169619#msg3169619 8/10 updated
This time we are using a traditional Gasket structure. What is quite characteristic is that we have prepared a PE film
The PE film will cause an interesting change to the typing sound of the whole kit. Interested friends can try it out.
3.Grounp Buy information
A. What's inclued in the kits?
Alloy case + power stand
Titanium plate frames + Titanium decoration plate
Copper Cupid nameplate
Stainless steel battery compartment cover
PC plate(with long slot, supported PCB stabilizers)
Dual-mode hot-swappable PCB (with flex cuts)
Daugterboard + USB cable
0.4mm PCB stabilizer shims
Poron plate foam
Poron bottom case foam
IXPE switch foam
Silicone gasket socks
Silicone connecting pillars
Rubber foot pads
4000mAh lithium battery
PVD copper custom keycap
Custom keyboard carrying case
Case allen key (TBD)
kit basic information:
Layout: 65%
Connection: Dual mode (wired/Bluetooth)
Battery capacity: 4000mAh
PCB: 1.2mm full RGB flex cut PCB (supports VIA editing)
Angle: 6.5°
Weight: 1.25kg
Main material: 6063 aluminum
Surface treatment process: Anodizing/Electrophoresis/Powder coating
B.Price
Anodizing: $269
E-coated:  $285
Powder coating: $309
C.add ons
Cupid wrist rest
We also prepared 11 colors (Same with kits) for Cupid wrist rest.
Check our IC post for more informoation: https://geekhack.org/index.php?topic=120312.msg3169619#msg3169619  8/18 Updates
And here is all color renders of wrist rest: https://imgur.com/a/0ERtu6X
Price: Anodization $94, Electroplating 100$, Powder Coating 109$
Plate:
Copper plate (supports PCB mount stabilizer)
FR4  plate (supports PCB mount stabilizer)
PC plate (supports plate mount stabilizer)
D.Date and Duration
From Spet 5th, 12:00AM EDT, and last for a months.(Depends to the vendor)
Duration: 4 months
4.Vendors:
USA: KeebsForAll https://keebsforall.com/products/cupid-65-keyboard-kit-by-chaosera
Korea: Monstargear https://www.monstargear.co.kr/160/?idx=926#prod_detail_qna
South America: FancyCustom https://fancycustoms.com/products/group-buy-cupid65-by-chaosera?_pos=1&_sid=0972c3b88&_ss=r&variant=44138537582766
Europe: Keygem https://keygem.com/products/cupid65-keyboard-kit-group-buy
Canada: Ashkeebs update it later
UK: Mechboards https://mechboards.co.uk/products/chaosera-cupid65-group-buy
Japan: Basekey https://basekeys.jp/products/cupid-65?_pos=1&_sid=f3ea3a7aa&_ss=r
Australia: Allcaps https://allcaps.store/products/pre-order-cupid65?variant=43434197156007
Philippines: Zion Studio update it later
Vietnam: The Keebs Store update it later
Thailand: Gaming planet https://gamingplanet.store/product/groupbuy-chaosera-cupid-65-%e0%b8%84%e0%b8%b5%e0%b8%a2%e0%b9%8c%e0%b8%9a%e0%b8%ad%e0%b8%a3%e0%b9%8c%e0%b8%94%e0%b8%84%e0%b8%b4%e0%b8%97-%e0%b9%84%e0%b8%a3%e0%b9%89%e0%b8%aa%e0%b8%b2%e0%b8%a2-wirele/
Singapore: Antidote studio update it later
5. Assembly video (keep updating)
Welcome to join our discord for more information:https://discord.gg/pnp98dRpch
« Last Edit: Thu, 07 September 2023, 00:44:17 by CHAOSERA »
Re: [GB]Cupid65 - Start from September 5th
« Reply #1 on: Tue, 05 September 2023, 11:22:22 »
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
« Last Edit: Tue, 05 September 2023, 12:27:59 by HoffmanMyster »
Offline HereisVic
« Reply #2 on: Fri, 08 September 2023, 21:36:45 »
Waiting for so long!!
Offline CHAOSERA
« Reply #3 on: Tue, 03 October 2023, 12:13:39 »
GB will close on Oct 5th.
Thank you for you guys supported
Offline keymaven
« Reply #4 on: Thu, 19 October 2023, 19:28:39 »
Group buy still appears to be open for the US supplier.
Offline PPmonster
« Reply #5 on: Sat, 18 November 2023, 02:03:07 »
I got Cupid65-Heartseeker yesterday1(17/11/2023). It looks good, fine work. I love it very much. It's my 1st custom keyboard. Thx Chaosera.
