Author Topic: [IC] Enter67 V2 (List of Global Agents updated)  (Read 9617 times)
Offline ProudCat
    • 骄傲的猫
« on: Wed, 30 August 2023, 22:14:18 »
Hello everyone, this is Kezewa Studio.It’s been a long time since our first product,Enter67. During this time, we have made adjustments to the materials, stabilized our production line, relocated our factory, and endured the arduous process of PCB development. Finally, we are proud to introduce our second product, Enter67 Tri-mod, along with an updated design.
Still, you have the option to choose from a wide range of 14 colors
The overall design of Enter67 Tri-mod retains the design language of R1 but incorporates several design changes. This version features a smoother and more rounded appearance with increased curved surfaces. The sharp edges at the front have been replaced with rounded corners, and various details have been adjusted. The curvature of the back, as well as the materials, sizes, and positions of the components, have been modified to enhance the overall aesthetic.
The most significant change is the addition of a dual structure and a three-mode version.
Top mount:
Gasket mount:
Structure:
Dimension:
Specifications:
1、Material: 6063 Aluminum.
2、Typing angle: 7 degrees.
3、Mounting method: Dual structure mounting. Players can choose between top mount or gasket mount according to their preferences.
4、Weight: Approximately 1.8kg (when fully assembled).
5、Color options: There are up to 15 colors available, including raw. The raw color is limited to 300 sets worldwide.
6、Weight options: The standard configuration includes brass sandblasted weight or stainless steel PVD weight (available in black, silver, or gold). An upgrade option is available for stainless steel rainbow PVD weight.
7、Plate material: The standard options include PC, aluminum alloy, POM, FR4, and PP. An upgrade option is available for carbon fiber.
8、PCB details: You can choose between a single-mode or a three-mode PCB. The PCB options include 1.2mm or 1.6mm thickness, both supporting hot-swappable functionality.
For the three-mode PCB, it supports wired, Bluetooth, and 2.4G wireless connectivity (all compatible with VIA firmware). This allows users to choose the connection method that best suits their needs and switch between them as required. The high-performance MCU is utilized, along with 2.4GHz FLASH microcontrollers for both transmission and reception. The PCB features 32 KB (16K+16K) SRAM and 512KB built-in FLASH, ensuring fast, stable signal transmission, and reliable connectivity. The transmission and reception ends are encapsulated in TQFN48 and TQFN24 packages, respectively, to ensure signal reliability, stability, and reduce interruptions and interference. The PCB also supports online updates, allowing users to access the latest features and firmware upgrades to maintain optimal keyboard performance. With the USB online upgrade function, users can easily upgrade and update the keyboard firmware without complicated procedures.
9、Pricing:
We hope everyone will like it. Kezewa is committed to providing the opportunity for players to enjoy high-quality customization without much effort, with excellent craftsmanship and relatively reasonable prices. Our goal is to create a stress-free and high-quality customization experience for keyboard enthusiasts, allowing them to fully enjoy the pleasure of personalized keyboards. Thank you for your support!
We will soon update the agent platforms for various countries.
Vietnam:https://thekeebs.store/
Singapore:https://ktechs.store/
South Korea:https://www.monstargears.com/
Thailand:aiglatsonstudio.com
Belgium:https://mykeyboard.eu/
UK:https://prototypist.net/
Germany:https://keygem.com/
Spain:https://eloquentclicks.com/
Australia:https://allcaps.store/
US:https://keebsforall.com/
China:kezewa.com
Join Discord : https://discord.gg/8P75398dF3
« Last Edit: Sun, 03 September 2023, 01:13:33 by ProudCat »
Offline DirtyGingy
Re: [IC] Enter67 V2
« Reply #1 on: Thu, 31 August 2023, 00:00:12 »
If the PCB is still flex cut, it's not much of a V2
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter67 V2
« Reply #2 on: Thu, 31 August 2023, 06:12:47 »
Not really, and a welding version will be provided
Offline kiru
Re: [IC] Enter67 V2
« Reply #3 on: Thu, 31 August 2023, 06:40:53 »
Cuold you check discord pm plz?
Offline ELE.WORKS
Re: [IC] Enter67 V2
« Reply #4 on: Thu, 31 August 2023, 09:38:21 »
Wouldn't the surface feel better?
Offline MagnumDex
Re: [IC] Enter67 V2
« Reply #5 on: Fri, 01 September 2023, 01:41:04 »
when the groupbuy start, like this month or next month??
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter67 V2
« Reply #6 on: Fri, 01 September 2023, 01:46:06 »
I am planning to start a group purchase next week and I am waiting for the release of video reviews.
Offline Boyten8
Re: [IC] Enter67 V2
« Reply #7 on: Fri, 01 September 2023, 04:39:45 »
Which creators got the keyboard?
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter67 V2
« Reply #8 on: Fri, 01 September 2023, 08:06:19 »
I will update the content later
Offline DuellM
  • Keyboard Fatty
Re: [IC] Enter67 V2
« Reply #9 on: Sat, 02 September 2023, 14:18:42 »
What Kind of coating is used for these? also Is the battery included and if so what size is it?
« Last Edit: Sat, 02 September 2023, 14:22:51 by DuellM »
Offline ProudCat
    • 骄傲的猫
Re: [IC] Enter67 V2
« Reply #10 on: Sun, 03 September 2023, 00:09:30 »
The colored parts are anodized, while the white parts are electrophoretic coated. The battery has a capacity of 3000mAh.
