Author Topic: [IC] Nyaong75 R2  (Read 13635 times)
Offline jmSur
[IC] Nyaong75 R2
« on: Fri, 01 September 2023, 15:00:01 »
Nyaong 75 Round 2 Interest Check
[Nyaong75 R2 IC notice]
  •  We are going to run GB for second round of N75 from 25th Sep. 2023 to 9th Oct 2023 (not fixed yet but around this date)
  •  Estimated fulfilment time : Late April 2024
  •  Max 400 Sets
  •  This GB includes
      Nyaong75 top and bottom case
      Aluminium plate
      Solder PCB or HS PCB
      Semi-transparent acrylic diffusers for both ears
      Bolts, bumpons, grommets, daughterboards and JST cable etc
      Packaging
  •  530USD(Solder PCB) / 545USD (HS PCB)
  •  FCFS : https://bahmstudio.com/
[Specification]
  •  Typing angle : 6 degrees
  •  Material
      Upper case : Alu 6061
      Bottom case : Alu 6061
      Front face ear : Semi-transparent acryl(acrylic diffuser)
      Bottom engraving : 1.5mm grooves
  •  Weight : 2.60Kg unbuilt
  •  Front Height : 21.5mm
  •  75 Layout - Bottom row(R6) supports only 1.25 1.25 1.25 6.25 1.25 1.25 due to the inside screw holes
  •  Aluminium plate
  •  Burger mounted on top case
  •  Inside screw holes
  •  PCB supports ANSI/ISO, soldering required, screw-In-stabs
  •  5x RGB LED on each ear(total 10 RGB LEDs)
  •  Bottom engraving : Butt and Face
  •  Colour : Black / Silver / Rose Gold / Yellowish Gold / Burgundy - You can choose these colors for top and bottom case
                  Black / Silver / Gold / Red - You can choose these colors for the plate
  •  Hot Swap PCB available
Detailed info can be found on below discord server.
https://discord.gg/VpGAHpsMU
« Last Edit: Fri, 01 September 2023, 15:03:36 by jmSur »
Offline Thevenny
Re: [IC] Nyaong75 R2
« Reply #1 on: Fri, 01 September 2023, 16:16:48 »
Rip europe, candykeys this time too
Offline nike1847
« Reply #2 on: Fri, 01 September 2023, 23:16:28 »
Wow.. Interesting!!
Offline Soundtrack
« Reply #3 on: Sat, 02 September 2023, 18:34:54 »
Wish there was a lilac option, but that rose gold has my eye.
Offline Bahm78
    • https://blog.naver.com/hjg7808
« Reply #4 on: Mon, 11 September 2023, 03:47:41 »
Looks nice! I want it!!
Offline JustMilica
  • A weeb
« Reply #5 on: Mon, 18 September 2023, 12:44:00 »
I'm outta the loop, what's up with CK?
Offline Juhsoa
« Reply #6 on: Wed, 20 September 2023, 11:28:58 »
I love this! I'm snagging one!
Offline JustMilica
  • A weeb
« Reply #7 on: Wed, 20 September 2023, 17:34:02 »
Damn, I just saw the approximate date for the GB. If it ends up being late October or November, I might actually be able to snag it 😔
