Author Topic: [IC]Hillstone switch  (Read 5084 times)
Offline moyu.studio
« on: Fri, 22 September 2023, 03:39:44 »
Hi, this is Moyu.studio
This time, we brought the Hillstone switch jointly launched by jkdk and xcjz(XCJZ is a renowned switch collector in the East, and his LUCY switches are quite popular in both Eastern and Western communities)
The Hillstone switch was jointly designed by jkdk and xcjz and manufactured by Bsun.
302687-0
Hillstone switch Specifications:
- Heavy tactile
- 56g spring(16mm)
- POM Lengthen stem
- Mixed nylon top housing
- POM bottom housing
- 5 pin
- 3.2mm Travel
- Made by Bsun
- lubrication
302689-1
302691-2
On the hillstone switch, we chose a combination of POM stem and POM bottom house to achieve a stronger feel and thicker sound when in contact.
Bsun's factory lubrication allows the switch to truly be used out of the box, without the need for reprocessing. Simply plug it into your keyboard and you can start your new experience.
302693-3
302695-4
Q&A
Q:Will the Hillstone Switch be a group buy?
A:No, we hope to use spot sales, which is more user-friendly for consumers and can get the switch in a shorter time. We have arranged production and manufacturing in advance, so it won't be long.
Q:Are you contacting the vendor?
A:Yes, we are contacting vendors around the world to enable more communities and enthusiasts to purchase. If you are a vendor and interested, please contact us.
302697-5
Hillstone switch typing sound
Vendor List:
US:Vala.supply
CA:Deskhero
EU:Keygem
UK:Mechboards
CN:Moyu.studio
VN:uniqmeck.store
Thailand:NTCH Keys
South America:Fancy customs
Singapore:Qwertyqop
AUS:Allcaps
Rest of the world:Moyu.studio
Join our Discord
Interest Check Form
« Last Edit: Fri, 20 October 2023, 21:38:36 by moyu.studio »
Offline takuto
Re: [IC]Hillstone switch
« Reply #2 on: Fri, 06 October 2023, 16:02:55 »
Ah yes, finally a new heavy tactile switch. BSUN has been making great switches lately, so I'm looking forward to this. They sound chonky in the sound test too, let's goooo
p.s. What's the peak weight?
