Author Topic: [GB] Protagonist (60%) *Updated*  (Read 51933 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« on: Thu, 28 September 2023, 23:07:04 »
The group buy has officially launched. Thank you all for the input and support.
Info: https://wiredinstore.com/pages/protagonist-landing
Configure: https://wiredinstore.com/collections/protagonist-collection/products/protagonist
Collection: https://wiredinstore.com/collections/protagonist-collection
Vendors:
- US: @wiredinstore & @loobedswitches
- KR: @geonworks
- OCE: @allcapskeyboards
- CN: @kezewa_
- EU: @deltakeyco
- TH: @aiglatson.studio
- SEA: @themechastore
- UK: @jae_prototypist
The Protagonist, by Wired In, is a 60% keyboard designed with modularity and a modern, minimalist aesthetic, in mind. The Protagonist is the first of many proprietary projects created via partnership between Wired In and Loobed Switches. It will be available at both the official WiredInStore.com and vendor LoobedSwitches.com for domestic and international fulfillment.
Join the Discord and have a hand in development:
Check out the landing page for an in-depth look
Key Features
The Protag, for short, is mounted with a leaf spring semi-proprietary grommet system that is customizable via varying gasket hardness. This allows for a beautiful sound profile right out of the box with the ability to perfectly tailor it to your typing preference. We're not kidding, this thing sounds absolutely amazing.
  • Interchangeable 'Keyframe' with only 4 screws that serves as an accent piece for tons of color combinations and different layouts.
  • Endless customization with our in-house Cerakote offerings
  • RGB Underglow
  • Hidden Case Screws
  • Hidden Daughterboard routing channel
  • Hefty weight for a premium feel
Endless possibilities. Infinite value.
With a three dimensional "Keyframe", the possibilities are virtually endless. Between exchanging the 'Keyframe' for different layouts, different material options, as well as in-house Cerakote colors; there is no limit to the level of personalization.
The Protagonist will start at $349 (brass weight) subject to change.
Specifications
Case options:
  • Anodized, copper, e-coat, or Polycarbonate
  • Black, Silver, Cream, Coffee, Pastel Blue, Lavender
  • Black Cherry Cerakote, Pastel Pink Cerakote, Light Botanical Cerakote, Dark Botanical Cerakote, USMC Red Cerakote, Carbon Grey, Copper Cerakote (Aluminum), McFlurry
Keyframe Options
  • Black Cherry (Cerakote), Pastel Pink (Cerakote), Light Botanical (Cerakote), Dark Botanical (Cerakote), USMC Red (Cerakote), Carbon Grey (Cerakote), Copper (Cerakote Aluminum), McFlurry (Cerakote)
Weight Options (Weight will have option with and without Protagonist text):
  • Aluminum (coated or any case/Keyframe color)
  • Stainless Steel (coated or any case/Keyframe color)
  • Brass
  • Copper
Plate Options:
  • Aluminum Plate
  • Polycarbonate Plate
  • Polypropylene Plate
  • Carbon Fiber Plate
  • POM Plate
  • FR4 Plate
  • Copper Plate
PCB:
  • 1.6mm, USB-C, Hotswap or Solder, QMK/VIA support
  • Designed by Gondolindrim
Other Specifications:
  • Typing Angle: 7 Degrees
  • Mount Semi-propietary grommet mount
  • Dimensions: 126.2mm x 316.7mm
  • Front Height: 18.8mm
  • Weight: 4 - 6.6lbs (assembled)
Kit Contents:
  • (1) 6063 Anodized aluminum "keyframe"
  • (1) 6063 Anodized aluminum bottom housing
  • (1) Weight (choice of material and finish)
  • (1) Protagonist60 soldered or hotswap PCB
  • (1) 5052 Anodized Aluminum Plate
  • (12) 60a Gaskets
  • (1) C4 DB and OG JST cable
  • (1) Protagonist carry case
  • (1) Hex driver
  • Necessary screws, feet, and other accessories
Pictures
Photographs of original prototype courtesy of Captain Sterling and Wired In.
Color Ideas
Additional Information
PCB Layouts
Addons:
  • Foam Kit - (1) PE foam (1) Poron plate foam (1) poron case foam
  • Aluminum Plate
  • POM Plate
  • FR4 Plate
  • Copper Plate
  • 30a Gaskets
  • 60a Gaskets
  • 90a Gaskets
  • Hotswap PCB
  • Solder PCB
  • Weights
  • Keyframes
Accessories:
  • Protagonist metal artisan designed by PJ Aiglatson Studio
  • Protagonist genuine leather wrist rest designed by Turbulent Labs
  • Matching anodized and Cerakoted cables
  • Wired In 'Ally' convertable screw / artisan tray
  • Fade switches designed by BowlKB, manufactured by Gateron
Show your support by adding to your profile:
« Last Edit: Mon, 25 March 2024, 17:42:07 by OnTheBrink »
Offline Cobertt
    • Control on Caps
Re: [IC] Protagonist (60%)
« Reply #1 on: Thu, 28 September 2023, 23:09:34 »
Very excited for the Protag.
HHKB Pro2 | Mira SE | FJELL | KARA HAZE | CW88 FNF WKL Wine | HHKB Prophet | Al.6 | Tengu | Prototype CW60 HHKB Skunkworxxx | Prototype K80 | Tokyo60 | Gingko65 |  Midway LE |  Kei | Frog TKL | Saturn60 | NRD Kaze | Panda Korn | Iron 165 FE | Caerdroia | Safa TKL
Offline Rhienfo
  • GOTHETIGES
« Reply #2 on: Fri, 29 September 2023, 03:17:31 »
idk how I feel about this. Bezels are way to big which makes this look not great to look at. You can do that blocky look and have it look well (brutal 60 v2 does it pretty well I feel) but this is a bit much. Also not a big fan of the weight and how it affects the sides of the board, but that's probably more of a preference thing anyway.
Also am I being clueless or are there no images of the plate, cause if they're aren't can you please show some pictures, it's funny if you are advertising a more unique mounting style and just not showing it (also explosion diagram if there isn't would be nice as well)
GLWIC though
Offline NSMN
« Reply #3 on: Fri, 29 September 2023, 03:57:22 »
I like the design but some information is missing
Offline The0rigina1
  • fumoposting
« Reply #4 on: Fri, 29 September 2023, 05:34:06 »
3KG for a 60? where did you get your numbers
Offline vhaarr
« Reply #5 on: Fri, 29 September 2023, 06:23:31 »
In the "Key Features" section you write "The Protag, for short". This is the only place in the post where you shorten the name. And "The Protag, for short" is longer than "The Protagonist".
I just found that extremely hilarous :-D
Carry on, I'll show myself out.
EDIT: Aww, I just noticed the signature image at the bottom of the post also says "PROTAG". Darn it!
But yes some information missing here. Also why does the IC require Discord handle?
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline kajahtaa
« Reply #6 on: Fri, 29 September 2023, 06:32:18 »
This is beautiful
Offline LoobedSwitches
  • Empoweing your typing experience
    • Loobed Switches
« Reply #7 on: Fri, 29 September 2023, 09:15:44 »
The Protagonist prototyped was weighed in fully built with an Alu plate, Copper weight with switches and keycaps at 3KG
Offline OnTheBrink
    • Wired In Store
« Reply #8 on: Fri, 29 September 2023, 09:17:31 »
Thanks for the input all. This is my first IC, so it is definitely super helpful.
GLWIC though
I will be updating the IC with an exploded render so you can see the inside. I added the note to the section with the renders in case you missed it, so I will update accordingly as soon as they're done.
As for the bezels, using and seeing the board, I respectfully disagree but it's all preference at the end of the day.
The board is quite heavy fully built with a copper weight and it was weighed with a scale. The max weight is with everything, including keycaps, switches, PCB, plate, and copper.
The IC shouldn't have a Discord handle as required. That must be an error. Let me go ahead and fix that.
Edited: Discord ID was not required but I made it clearer that it's optional and also added the option to include any socials in case people want to communicate more.
Again, thanks for all the invaluable input and help! If you all think of anything else that may help, do not hesitate to let me know.
« Last Edit: Fri, 29 September 2023, 09:32:28 by OnTheBrink »
Offline sugarfreemedia
« Reply #9 on: Fri, 29 September 2023, 14:02:13 »
Are the HHKB blockers 1.5u on both sides?
Offline OnTheBrink
    • Wired In Store
« Reply #10 on: Fri, 29 September 2023, 16:29:26 »
Yep! proportioned on both sides.  :)
Offline OnTheBrink
    • Wired In Store
Re: [IC] Protagonist (60%) *Updated*
« Reply #11 on: Sat, 30 September 2023, 15:39:46 »
Added exploded view.
Added new black Keyframe with Cerakote black cherry base render.
Pictures of the plate and a closeup of the mounting system will be added by tomorrow.
Offline Mechboards
  • Mechboards UK
    • Mechboards
« Reply #12 on: Mon, 02 October 2023, 04:28:26 »
This looks really nice - I really like the bezel accent and blocky shape.
Offline OnTheBrink
    • Wired In Store
« Reply #13 on: Tue, 03 October 2023, 00:34:16 »
Thank you! The IC has been going really well and we’ve been loaded with responses. I am really excited to see how people mix the elements to create unique color options or do something unique with the poly as there’s multiple different ways to show off the internals.
To add, the fact that the acoustics are top tier too has us very optimistic about the board’s place in the community.
The copper on poly on copper picture we just posted really exemplifies just how gorgeous the squared off and proportioned look is.
Once promo units are here, we’ll get the GB started as those get shipped out to streamers.
Offline vhaarr
« Reply #14 on: Tue, 03 October 2023, 03:33:41 »
Where is this photo?
Offline OnTheBrink
    • Wired In Store
« Reply #15 on: Tue, 03 October 2023, 10:00:25 »
I added it to the IC above. It's towards the top and on the Instagram.
Offline vhaarr
« Reply #16 on: Tue, 03 October 2023, 11:58:04 »
Aaaah d'oh I just looked in the Pictures section - scrolled right past it - thank you :-D
Offline antsinyourpants
« Reply #17 on: Fri, 13 October 2023, 02:52:36 »
Looks good! You do realise this means you're going to have to come out with an Antagonoist keyboard later down the road right?
Offline OnTheBrink
    • Wired In Store
« Reply #18 on: Sun, 15 October 2023, 22:36:13 »
Ya know, it's funny you should say that...  :cool:
Ping me on Discord: Wired.In
Offline OnTheBrink
    • Wired In Store
« Reply #19 on: Fri, 20 October 2023, 11:23:00 »
Not a ton of updates, but a few to point out:
Due to interest and revised quotes, we’re confident we can make the price $350 with brass! This is down from $399.
Weight will have the option for textless.
Also, I am not sure why this was confusing people on the IC but it may be my fault. All pieces will have a copper options AND copper Cerakote. Copper is expensive and we are offering copper Cerakote for people to have the ability to get the color at a more affordable price. No, it’s not going to be as perfect as real copper, but it is a nice alternative for people who may not have the extra money to splurge.
Offline hardreturn
« Reply #20 on: Mon, 30 October 2023, 14:33:30 »
Very cool looking, can't wait to hear some tests, see a build. Any idea on when the GB will go live?
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #21 on: Mon, 30 October 2023, 15:12:33 »
Man if this had a Cherry lip it would be double chef's kiss! Very cool as it is though, I like this a lot more than other boards I've seen that has interchangeable frames for regular, WKL, HHKB!
Offline OnTheBrink
    • Wired In Store
« Reply #22 on: Wed, 01 November 2023, 12:33:51 »
Acoustics are top tier. And I really mean top shelf. For the money, it is unreal how good this board sounds. Hit me up on Discord and I will share some tests I did: Wired.In
I just want to do it in a room that is better treated for the public tests (plus streamers will with promo units) as there is an echo but you can still get a good idea of what I'm talking about.
Thank you! Yeah, wanted to implement something that would be fun for people to play with and customize instead of just interchangeable blockers and it morphed into the whole 'Keyframe' idea. Just a little bummed we needed to remove 6.25u as a spacebar option due to the cuts in the plate having an affect on acoustics but still plenty of personalization opportunities.
Offline NeonThunderX
« Reply #23 on: Tue, 07 November 2023, 10:51:45 »
GLWIC, excited for this!
Offline OnTheBrink
    • Wired In Store
« Reply #24 on: Fri, 01 December 2023, 19:00:07 »
Updates:
Added the landing page which really has the most information now. The GH post is really difficult to edit at this point so please check that out when you can. It has absolutely everything in reference to the board. You can even click "configure yours" to check out the configurator we built (still a work in progress) to play around with some color combos. Don't miss the accordion at the bottom as well and the Notion roadmap.
Added color ideas which are also on the landing page to give an even better idea of some popular combos from the IC as the configurator is limited, obviously, in its capacity to show true to life imagery.
Added logo weights for those who do not like the Protagonist font on the weight.
Added some more poly and copper renders which is crazy popular.
Offline kaworu
« Reply #25 on: Sat, 09 December 2023, 06:41:50 »
Beautiful, sadly not 6.25u spacebar so I'm out. GLWIC
Offline OnTheBrink
    • Wired In Store
« Reply #26 on: Tue, 12 December 2023, 09:49:31 »
No problem. Thank you for the kind words.
6.25 just wasn't feasible given the acoustics and to create another plate and PCB for it would make skus even more ridiculous. If you reconsider, we plan on releasing it after GB has concluded and boards go out.
Offline h3lli0n
    • oliversphotoblog.com
« Reply #27 on: Sat, 16 December 2023, 09:30:47 »
Regarding PCB, will source code be avaible on Qmk Git repository ? Do you consider Vial support as well ?
Offline zlobin356
  • Hi! My name is zlobin!
« Reply #28 on: Fri, 22 December 2023, 10:55:52 »
The idea with this top cover is good!
Collection state: OTD The Cheat, Tofu60 v1, Hal.6
Offline kaworu
« Reply #29 on: Sun, 24 December 2023, 02:16:00 »
I guess the PCB could support both 7u and 6.25u without much impact on either acoustics nor SKUs right? The current plan is unclear as the description's PCB layout shows only 6.25u (which I guess is wrong). If I only need to modify the plate file and get a custom cut I'll reconsider for sure as the poly / copper is very tempting!
« Last Edit: Sun, 24 December 2023, 06:39:10 by kaworu »
Offline vhaarr
« Reply #30 on: Mon, 25 December 2023, 03:04:33 »
Both the PCB image/render on the landing page and the layout image shown here in the IC and the landing page (same one) are confusing really.
Here's what you've said before:
But like kaworu said, judging by the layout image provided in the GH IC+landing page, you're mistaken about your own layout.
And judging by the PCB image/render, first it doesn't match the layout image, and it seems to be 1.25 + 1.25 + 1.25 + 6.25 + 1.25 + 1.25 + 1.25, which is a really weird layout. But I'm not a good judge of PCB lengths, so I'm probably wrong about that.
Offline Kerasan
« Reply #31 on: Wed, 10 January 2024, 03:39:30 »
Is this coloring planned to be done? It is rarely seen and I think it is one of the most beautiful combinations, I would love to get it in this livery.
Offline SammyJim
« Reply #32 on: Wed, 10 January 2024, 14:24:56 »
I think this board is beautiful. I love big bezels. Almost wish there were fewer color options, at least for the case. Makes it almost too hard to choose. Feel like it's overkill that you can get all weights in all of the case colors, too. But there will definitely be a lot of unique combos out there!
I love that the swappable keyframe also lets you change the layout, but I wish they were held on by magnets instead of screws - I feel like that would really underline the flexibility of the design.
Offline tactilesbad
« Reply #33 on: Tue, 16 January 2024, 10:03:09 »
need that orange in the renders :(
Offline PPmonster
« Reply #34 on: Sun, 11 February 2024, 07:08:36 »
When? I can't wait!!!!!!
Offline whysoda
« Reply #35 on: Tue, 12 March 2024, 13:46:05 »
Wired! Can't believe I missed this post, super super excited for you and to see this come to life. Best of luck, this looks fantastic :D
Offline vhaarr
« Reply #36 on: Wed, 13 March 2024, 01:40:28 »
Quote from discord: "The group buy will begin worldwide on March 25th, 2024 and end on April 30th, 2024."
« Reply #37 on: Wed, 13 March 2024, 09:28:54 »
At long last...
IT'S HAPPENING!
Sent from my Pixel 7 Pro using Tapatalk
Offline mr_foggy
  • neue = nope
« Reply #38 on: Thu, 14 March 2024, 13:51:40 »
so many tempting 60s on the market right now... need to sell something.
Offline LumiP
  • A lil Faedude on the net. Fave layout is FRLTKL!
    • Sometimes I do builds on Twitch! :3
« Reply #39 on: Thu, 21 March 2024, 00:53:36 »
I'm wondering this same thing. In the config all we can do is Stainless Steel weight from what I can see, which isn't the same. Sadness.
Current Boards: Aaru TKL Old Dark Sand, Drop + Planck Purple, Mr Suit WKL Black w/Gold Chamfers, Sangeo60 Black, KBD67Lite White, D45 E-Grey, Wind X Pink, NCR 80 Beige, QK65 Dark Green, Gentleman65 Black, Av4 Claymore, TGR x Monokei Tomo Suave Blue, Heracles80 Holy White, Snake60 Rust, Array E-White, Capsule E-White, QK75 E-White, Zoom75 Milky Green, QK80 Black, Envoy 65 PC, Mode Sonnet Ice Blue, Cycle 7 Lavender, E-White; Neo70 Retro White, Black; Reflection Chocolate, Neo80 Champagne, Matra Alice 90 Glossy Red;
Offline OnTheBrink
    • Wired In Store
Re: [GB] Protagonist (60%) *Updated*
« Reply #40 on: Mon, 25 March 2024, 17:43:17 »
Final update as group buy is live.
Thank you all for the amazing input and support. We couldn’t be happier with the board.
Final look and Instagram post: https://www.instagram.com/p/C48YKG-sl3L/?igsh=MW5vaTd0dnBhY3Jyeg==
Offline sK0pe
« Reply #41 on: Fri, 21 November 2025, 06:20:02 »
Some belated feedback, if you guys ever rerun Protagonist please do not use AllCaps as an OCE vendor.
I put in a premium order for the Protagonist through them.
The vendor took my money gave me updates of when the items arrived in Australia and stated when it was to be shipped locally (late April) and then didn't send out my order or never placed it to begin with.
The vendor refused to respond to tickets, email or direct Discord messages.
Already reported to Visa.
First time I have had this egregious an issue over 12 group buys.
Unfortunate since I had already bought matching caps and specific switches for the build  ^-^
