Author Topic: [IC] Jimi (机美): the 60XT with curves that keep on giving.  (Read 9144 times)
Offline logaboga
    • OIOIOI.WORKS Website
« on: Fri, 29 September 2023, 13:05:37 »
Please fill out the Interest Check form here: https://forms.gle/nHe8xf3fauko3L688
This project is indefinitely on hold due to vendor issues
Introduction
While I've been in the hobby as a collector for a while, it was only about half a year ago that I started considering designing my own keyboard. After many many iterations and drafts, I think I've finally landed at something I really like and want to share with the world.
I present, for your consideration: Jimi (机美).
Overview
Jimi (机美) is a linguistic amalgam of the three cultures/languages I grew up with: Korean, Chinese, and of course, English. It means mechanical beauty.
I love curves in keyboards. The trouble is that these curves are seldom found in boards that don't cost an arm and a leg. My biggest goal with Jimi is to make a board with unique visual cues that isn't prohibitively expensive.
I'm leaving out the extra frills that define more premium keyboards in order to achieve this objective: no external weight, minimal design work/machining time committed to places people won't be seeing most of the time, and a curated set of 3-4 colours.
Details
- Layout: Tsangan 60XT (WK or WKL options)
- Mount: Tadpole
- Materials: Aluminum 6063, Brass internal acoustic weight
- Typing Angle: 7 degrees
- Front Height: 17.1 at top of lip, 14.1 at bottom  (~21.1mm EKH)
- Plates: Aluminum, FR4, PP
- PCB: Custom, uses Unified C4 daughterboard
Additional details:
- will be using 8mm 3M bumpons
- 6x M2 case screws, 4x M3 daughterboard screws, 3x M3 weight screws
Mount and Layout Info
Tadpole mount cross-section
Plate with mounting points
PCB supports Stepped Caps Lock, 1.75U RShift, and split Backspace
Exploded view (updated 30/11/2023)
Pricing
aiming for $350, depending on interest
GB & Vendor Information
Ano Colours
Silver
Dark Blue
Black
Project Timeline
Interest Check
Prototype
Group Buy
More/Old Renders
Special thanks are owed to my friend ziltoidthealtoid, who designed the PCB for this board and tolerated me incessantly bouncing ideas off him, as well as lampmk, stinky, and chu for their help and guidance.
A big thank you is also owed to ImperfectLink for making KRK and taking so many steps out of the Blender process.
Live changes:
working on internal weight design, acoustics optimisation (29/09/2023)
Change log:
Added placeholder exploded view (01/10/2023)
Added WKL top case (not pictured yet) (01/10/2023)
Updated exploded view (04/10/2023)
Overhauled IC (30/11/2023)
Cleaned up IC (13/12/2023)
Vendor inquiries:
@loganchoi on Instagram
logan.choi on Discord
« Last Edit: Sun, 28 July 2024, 11:29:46 by logaboga »
Offline ZiltoidTheAltoid
Re: [IC] Jimi (机美): the 60XT with curves that keep on giving.
« Reply #1 on: Fri, 29 September 2023, 13:11:35 »
Thank you to NewJeans for being the only thing I listened to while making the pcb :)
« Last Edit: Fri, 29 September 2023, 18:51:27 by ZiltoidTheAltoid »
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #2 on: Fri, 29 September 2023, 14:35:42 »
add some bumpon cutouts
Offline logaboga
« Reply #3 on: Fri, 29 September 2023, 16:30:17 »
Working on that! Debating between SKUF or bespoke solutions right now.
« Last Edit: Fri, 29 September 2023, 20:57:23 by logaboga »
Offline lampmk
  • box art peddler
« Reply #4 on: Fri, 29 September 2023, 18:01:59 »
 :thumb: nais
My collection -
Ovinnik - Spyder TKL - FMJ TKL - Keycult 1/60 Raw - Lin Whale - Duck Lightsaver V1
Offline warhopper
« Reply #5 on: Fri, 29 September 2023, 21:05:51 »
Really love this design, side profile looks great. Can’t wait to hear more cause I am for sure in on one!
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #6 on: Sat, 30 September 2023, 06:04:02 »
60xt good
tadpole good
Offline jiminojimi
« Reply #7 on: Sun, 01 October 2023, 03:07:11 »
I am Jimi.
I approve the sexy curves.
I want arrows though...  will you consider tkl in future with these curves?
Offline logaboga
« Reply #8 on: Sun, 01 October 2023, 12:04:36 »
Haha hi Jimi! While I don't want to plagiarise myself and make the exact same design scaled up, I will probably be working on a TKL with a similar design language at some point in the future.
« Last Edit: Mon, 02 October 2023, 13:15:30 by logaboga »
Online Rhienfo
  • GOTHETIGES
« Reply #9 on: Sun, 01 October 2023, 21:40:29 »
like the sides, but can't really say much else until the protos come out. But from the renders it seems like the start of a good project.
GLWIC
Offline Sm0k3d0uT
« Reply #10 on: Wed, 06 December 2023, 16:26:04 »
I needs muh JIMI
Offline PrizeOcelot5911
« Reply #11 on: Wed, 06 December 2023, 21:27:47 »
