Author Topic: [GB] LM60 Stripe (detail in al, brass, copper, pc and wood) - WK, WKL and HHKB  (Read 112807 times)
Offline daviddgm
Another model of LM Series with clean and easy to mount design, preserving the beauty and sound
Available in 60% and 65% (please contact) with layouts WK WKL HHKB
Highlight points
- Clean and beautiful design, easy to mount
- Same plate and mount of LM60 V2
- RGB light through polycarbonate stripe
- Different colors and materials: aluminum, brass, copper, wood and PC
- Front angle
- Plate for multiple layouts
- Extra plates and stripes are available
- Available colors: champagne, beige grey and navy blue - Contact if you want different
Mount system
Mount Shock Absorption Balls - used in drones (will be included)
Silicone wire seals - Little more flex than above option (will be included)
The plate
Details
Aluminum with stripes of aluminum, brass, copper, pc and wood
Case Angle: 6.5 degrees
Mounting: Rubber Shock Absorption Balls or Silicone Wire Seals
Case Material: 6063 aluminum
Making process: CNC - sandblast - anodizing
Front Height: 19 mm
Back Height: 21 mm (with chamfer) and 32 mm (before chamfer)
Weight: ~1400g and ~1800g (mounted with brass plate and brass/copper stripes)
Plate:  Aluminum, Brass, PBT (default is aluminum, if you order with brass/copper stripe option you will receive the two - please contact for PBT)
PCB Compability: GH60 style (GH60, DZ60, BM60, etc) for LM60 Stripe; DZ65RGB and BM65RGB (and others) for LM65 Stripe (please contact for 65%)
Prototype
The internal design and dimensions are the same of LM60 V2, that was fully tested and approved. Check the videos.
https://youtube.com/shorts/AF4tVdQx4gs
https://youtube.com/shorts/sNy4kU_97B4
What will be included
- LM60 Stripe shell case
- Aluminum Plate (others as extra)
- 2x Stripe/bar made of Polycarbonate (others as extra)
- 4x Stainless steel screws M2
- Silicone Mount Shock Absorption Balls and Silicone Wire Seals (as second option)
- Silicone Rubber feets
Timeline and fulfillment date
January-February: 15-14 GB
February-March: Production
April: Shipment (Will be available: Aliexpress forwarding, Fedex/DHL and Germany forwarding to EU).
Price
One set USD 139.00+
Two sets USD 110.00/each (please contact)
Thee sets USD 85.00/each (please contact)
Solder PCB USD 30.00
Solder PCB with RGB underglow USD 35.00
Hotswap PCB (with RGB Underglow header for led strip) USD 35.00
130pcs Hotswap pin sockets 1.5mm USD 15.00
Order Link
https://lmkeyboards.myshopify.com/
Regards,
Eng. David Martinz - LM Keyboards
daviddgm at gmail
@lm_kbd
« Last Edit: Wed, 17 January 2024, 14:50:34 by daviddgm »
Re: [GB] LM60/65 V3 - Monoblock, mount screw in bushing - GB Live
« Reply #1 on: Mon, 16 October 2023, 16:55:00 »
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
Offline OJtheTiny
« Reply #2 on: Mon, 16 October 2023, 20:58:38 »
no proto, mounting looks incredibly tedious to assemble. Truly a GB of all time
Offline daviddgm
« Reply #3 on: Wed, 18 October 2023, 11:56:25 »
Yes, this mount system is more "tedious" than others, but no more than mount stabs or lube switches... 😆 This board is intended for those who want the benefit of monoblock/unibody and to reduce a little the production time and price.
On the next days we will post the prototype testing.
« Last Edit: Wed, 18 October 2023, 14:03:50 by daviddgm »
Offline daviddgm
Last days of GB.
Offline vhaarr
Wait. Beech wood and walnut wood HHKB layout?!
1. Do you have photos of these?
2. How hard is it to break the blockers of the wood case?
3. dgmelet.com is forcing me to select the "Extra plate" alu/pbt/brass option for $30 USD extra. Why do I need to buy two plates?
4. Is it even possible to buy a wood case with a weight?
5. Does it include a PCB?
6. Do you have any videos of the mounting system except the very bad youtube short video you did where we can't see anything?
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline daviddgm
1. No, but I can get photo with factory of others keyboards modelos.
2. Not easy to broke, It has 5mm.
3. Fixed. Not required to choose.
4. Yes, It is possible.
5. PCB not included.
6. We Will post the video next week.
We can offer full video showing the product and testing before the shipment, If not like anything you can choose the refund.
Offline vhaarr
Please see if you can get a photo of both types of wood.
Is the wood finished in any way or untreated?
EDIT: Also how is the weight mounted in the wood case?
Offline daviddgm
Here, some photos of cases made before by the cooperation factory.
The wood is finished (or not If required). The weight, depending the plate material 700-950g.
« Last Edit: Thu, 26 October 2023, 15:06:21 by daviddgm »
Offline SwitchKeys
    • SwitchKeys
Is this being sold on a Brazillian auto parts web store?
Offline daviddgm
Re: [GB] LM60/65 V3 - Monoblock (Al, Wood, PC) mount screw in bushing - GB Live
« Reply #10 on: Thu, 26 October 2023, 20:30:11 »
Yes, the Auto Parts Store is mine. I think many people like the project, but do not want or trust to order directly from our link... No reason for that, LM60 V1 and V2 were delivered with full success and satisfaction.
If we sell it on vendors the price would be up by 30-40%.
« Last Edit: Wed, 08 November 2023, 18:25:03 by daviddgm »
Offline daviddgm
« Reply #11 on: Tue, 12 December 2023, 07:45:45 »
Hi! Last chance to order LM60 V3.
We can accept just 20% of payment and the remain when production done. Please contact.
Offline nathanchere
« Reply #12 on: Wed, 13 December 2023, 17:06:05 »
Still no aluminium prototype dispayed as promised months ago, delivery "1st half" supposed to be happening now but obviously not a chance in hell, and still taking late entry payments. This reeks of scam.
Offline nathanchere
« Reply #13 on: Wed, 13 December 2023, 17:23:46 »
Just in case it seemed like a harsh evaluation, let me clarify:
We made 3D printing prototype and will be made another aluminum prototype before the batch production.
Suggesting one of:
  • the prototype turned out poorly
  • the prototype hasn't even been done yet
  • there was never going to be any prototype
October: 11-31 GB
November: Production
December and January 2024 (first half): Shipment (Will be available: Aliexpress forwarding, Fedex/DHL and Germany forwarding to EU).
December
  • still taking payments
    still no prototype
    still no production
Offline daviddgm
« Reply #14 on: Thu, 14 December 2023, 05:36:00 »
No samples and still taking orders because no MOQ reached yet! We are a small Company owned by me that really like to design and make keyboards and want to use GB, in the real meaning, to make It happen. But now many users just want to choose big projects that send dozens of samples to the content creators.
Just for reference, we delivered 80 sets of LM60 V1, 25 sets of LM60 V2 and now trying the LM60 V3.
Follow our Instagram @lm_kbd
« Last Edit: Thu, 14 December 2023, 05:38:27 by daviddgm »
Offline vhaarr
« Reply #15 on: Thu, 14 December 2023, 11:26:53 »
I think if you made another website like lmkeyboards.com with a simple shopify site and stripe checkout, many more people would be comfortable ordering.
But maybe not.
Offline daviddgm
« Reply #16 on: Fri, 15 December 2023, 10:36:31 »
Thank you! Suggestion accepted.
But maybe not.
Offline daviddgm
Now our store is Shopify.
Offline vhaarr
Re: [GB] LM60/65 V3 - Monoblock (Al, Wood) mount screw in bushing - Shopify Store
« Reply #18 on: Fri, 15 December 2023, 14:59:45 »
Haha that was quick, good job :-)
There's a few things you can do to make the site a lot better, for example
(1) prices are only shown in BRL$ but I think shopify will let you show it in the visitors detected currency automatically
(2) selecting different color frames should change the active photo/render
(3) seems to be missing lots of case colors and also wood
(4) I can only select shipping to Brazil, no other countries
(5) it might be a good idea to write a better description for the V3, just go read on other stores what they write - for example what is actually included in the purchase and specify that PCB is NOT included, and put a link to the GB post here
(6) it might be a good idea to upload product pages for V1 and V2 to show the history, just put them "out of stock" or whatever, and put a link in the descriptions to the GH posts
Also since you say you sold a few of V1+V2, it would be great if you could show customer photos or videos of those somewhere.
But anyway please don't do anything just because I write it. I'm just trying to be helpful but if you spend lots of effort and nothing comes from it then don't blame me please :-P
Offline daviddgm
Hi! We have changed the design and open a new GB window!
« Last Edit: Wed, 17 January 2024, 05:24:38 by daviddgm »
Offline nathanchere
.... and quietly dropping the prototype from the new timeline. This heavily reinforces my earlier stated concerns.
Offline daviddgm
We are still trying to make prototypes (factories charge high prices if is sample qty) or at least sell few to make first round (with full satisfaction warranty). But now this business/hobby is so hard, some big company/projects with low price and few GB that failed...
« Last Edit: Wed, 24 January 2024, 04:05:46 by daviddgm »
Offline daviddgm
Special condition on our Instagram for who want to enter on the first batch order. @lm_kbd
Offline SwitchKeys
    • SwitchKeys
 :confused:
Offline daviddgm
 :confused:
You should collaborate with the project instead of being just critical
How to make MOQ of 25 sets without at least 12-15 sets sold?! We have funds to make, but the preferences about layout, colors and materials...
