Author Topic: [CLOSED][GB] Heavy Shell Pare 65 keyboard  (Read 20215 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Tue, 17 October 2023, 22:42:21 »
Pare65 is designed by Heavy Shell, which is well-known Keyboard studio for high-quality keyboard kit.
The aluminium-alloy case with CNC technique gives Pare65 a good shape. Moreover, Pare65 has a removeable aluminium-alloy top cover.
The switch RGB is on the back of its FR4 plate. It would be a good thing for RGB-lovers. Even you want to try your own PCB which isn't RGB, you still have the RGB effect when you put your own PCB into Pare65.
Timeframe
GB closed on 31st October 2023 PST
Estimated Delivery in December 2023
SPEC
Keyboard weight about 1.6 KG
VIA Support
Aluminium alloy case
hot swappable PCB
south-facing Switch LED
FR4 plate
3500mAh battery
Bluetooth and wire mode
about 8.5 degree angle.
65% layout
GB NOW
« Last Edit: Fri, 10 November 2023, 20:30:47 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: [GB] Heavy Shell Pare 65 keyboard
« Reply #1 on: Tue, 17 October 2023, 22:43:04 »
IN THIS GROUPBUY, HEAVY SHELL OFFERS TWO KITS FOR YOU.
COMPLETE KEYBOARD KIT
You will get a complete ready-to-use Pare65. It will have TTC HEX switch and Domikey Keycaps. All you need to do is to take it out and plug into your computer, then enjoy the fun that Pare65 brings to you.
TTC HEX Switch
POM housings
POK stem
Actuation Force 50gf
Bottom force 56.5gf
2-stage glod-plated spring
Domikey Keycaps
Triple-shot ABS keycaps
Cherry profile
BAREBONE KIT
If you are an enthusiast and want to make it more like your taste.  Barebone kit is definitely a better choice. You take joy in the process of assembling Pare65. To instal the switch and keycap set you like.
