Author Topic: USB-C Fitment - Case Options - PCB Submission  (Read 5170 times)
Offline russeree
  • Creator of NyanOS | Nyan Keys
« on: Sat, 21 October 2023, 16:42:19 »
Hey,
New here so if am doing anything wrong let me know. With that said I have designed, simulated, and mocked up an FPGA based keyboard design where all keys are wired in parallel to individual 8bit per key debounce counters... My boards are routed and ready for submission.
My questions is the framework for my first PCB is https://github.com/evyd13/plain60-c compatible with a TOFU case? If not what alternatives exist?
The goal was a GH60 base without the mini usb
Thanks in advance.
Nyan KeysMech keyboard
Nyan OSOperating System / Firmware
Offline fpazos
Re: USB-C Fitment - Case Options - PCB Submission
« Reply #1 on: Sun, 22 October 2023, 03:17:25 »
It will. Maybe you find some problems depending on the cable but the conector shouldn't be a problem.
Offline russeree
« Reply #2 on: Sun, 22 October 2023, 03:50:39 »
Thank you very much. Going to sit on my design until tomorrow night and then submit for mfg. Maybe I will catch an error in my sleep.
