Author Topic: Any differences between MX blue keyboards?  (Read 2381 times)
Offline mcnabb100
« on: Fri, 15 October 2010, 23:36:18 »
Hi, I've been looking for a keyboard for a little while, and i've pretty much decided I want to get a board with cherry blue switches. This will be my first mechanical keyboard, and my question is, will there be any noticeable difference between say, a das keyboard and a filco if both have blue cherry switches?
Offline Phaedrus2129
« Reply #1 on: Fri, 15 October 2010, 23:40:50 »
Not between Das or Filco since they're both basically the same keyboard (main assembly is the same anyway, both are made by Costar).
But between manufacturers there are some differences due to the mounting method. Costar plate-mounted feels different from iOne plate-mounted feels different from Cherry PCB-mounted. The differences are subtle but noticeable to sensitive hands.
It's more noticeable with some other switches. MX browns vary widely in feel, plate mounted and PCB mounted are hugely different feeling, and the PCB mount ones from Cherry can vary with the size of the PCB and the weight of the keycaps (former has more effect than the latter).
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline mcnabb100
« Reply #2 on: Fri, 15 October 2010, 23:44:23 »
Quote from: Phaedrus2129;234536
Thanks, is either method decidedly better or is it pretty much subjective?
« Reply #3 on: Fri, 15 October 2010, 23:50:32 »
Mostly subjective.
I will say iOne browns feel a little off
Offline mcnabb100
« Reply #4 on: Fri, 15 October 2010, 23:59:45 »
Quote from: Phaedrus2129;234541
Mostly subjective.
OK thanks :biggrin:
Offline ironman31
« Reply #5 on: Sat, 16 October 2010, 12:53:19 »
From my experience cherry blues vary hugely depending on the keycaps that are used. When using cherry doubleshots, the pitch is higher and they feel lighter and more crisp. they feel lighter to me but that could just be from the difference in sound and how my brain perceives it
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline gregh
« Reply #6 on: Sat, 16 October 2010, 13:55:42 »
I have the Filco and the Das Pro. Both are Cherry MX Blue.
The Filco keyboard, in my opinion, is substantially better made than the Das. You can read my little post in the Reviews section for further information.
So, I definitely recommend going with the Filco.
