Author Topic: How to make a homemade 5-din -> PS/2 connector?  (Read 7005 times)
Offline Pylon
« on: Sat, 16 October 2010, 10:09:45 »
I just bought 2 model Ms at a yard sale for $1 each - a 1986 1390131 and a 1993 Lexmark branded 1398601. The problem is the guy only had one cable and it's a 5-din type. I'm too cheap to buy a cable or an adapter, so I'm probably going to build one myself.
Is it possible to make a homemade 5-din adapter? Thanks.
« Last Edit: Sat, 16 October 2010, 10:12:13 by Pylon »
Offline WhiteRice
« Reply #1 on: Sat, 16 October 2010, 10:15:15 »
It's certainly possible, do you have any old ps/2 connectors to splice?
Offline Pylon
« Reply #2 on: Sat, 16 October 2010, 10:16:32 »
Yeah, I could cut one off one of my rubber domes.
Offline WhiteRice
« Reply #3 on: Sat, 16 October 2010, 10:24:48 »
It might be even simpler than I was suggesting...
Linky
ripster or kishy would probably most qualified to answer.
Offline Pylon
« Reply #4 on: Sat, 16 October 2010, 10:30:50 »
I'm also probably going to sell the 1390131 and keep the Lexy. Both of the Model Ms don't feel as great as I expected, though better than my Quietkey. The force curve is WAY different.
Offline JohnElliott
« Reply #5 on: Sat, 16 October 2010, 11:12:45 »
I've done it for Terminal M to PS/2. It's pretty straightforward:
1. Get hold of a lead with a PS/2 plug at one end. I bought mine from RS Components, but if you've got a scrap keyboard you could also cannibalise it from there.
2. Get hold of a 5-pin DIN socket. I bought mine from RS along with the cable.
3. Use a multimeter to work out which wire in the cable corresponds to which PS/2 pin.
4. And solder them to the appropriate pins in the DIN socket.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #6 on: Sat, 16 October 2010, 11:37:25 »
Quote from: JohnElliott;234739
Or
3.' Ask teh interwebs for the respective connector pinouts.
Offline JohnElliott
« Reply #7 on: Sat, 16 October 2010, 11:41:53 »
Quote from: keyb_gr;234749
Or
You need to do that as well. The pinout will tell you which pin is +5v, which is Data and so on, and the multimeter tells you which wire at the other end of the cable is connected to that pin.
Offline keyb_gr
  • Cherrified user
« Reply #8 on: Sat, 16 October 2010, 12:33:07 »
Quote from: kishy;234756
Adapters are cheaper to buy...just do that.
ACK. Not worth the trouble.
Offline Pylon
« Reply #9 on: Sat, 16 October 2010, 12:38:57 »
I just committed a serious crime then...
Offline Pylon
« Reply #10 on: Sat, 16 October 2010, 14:26:14 »
Alright, I'm typing on my Model M (the Lexmark in my sig) now. Thanks guys.
I basically hacked apart my SDL cable and more or less spliced a PS/2 cable from my KB-9970 onto it. I more or less guessed which cables went onto which, based partly on the colors. Thank God I didn't kill the controller or the PS/2 controller on the motherboard.
This is a really high force keyboard.
