Author Topic: Gateron Oil Kings - Clean and Re-lube?  (Read 7286 times)
Offline coelacanth
  • cheesed to meet you 💪😎
« on: Thu, 02 November 2023, 02:28:16 »
Would there be much benefit to cleaning and re-lubing oil kings? I know it's a bit counterintuitive to buy pre-lubed switches only to lube them yourself, but I was curious if it would make a noticeable difference or if it'd just be a waste of time
I figured I'd clean and re-lube a couple (maybe 3 or 5) to get a feel and see if it's something I'd want to do for the whole board. Though I wanted to ask here just in case someone else has already done some research/experimenting, which is likely!
Geonworks Frog F13 TKL | Gateron <3  —  1984 Volvo 240 DL 2l OG Redblock Owner
Offline Rhienfo
  • GOTHETIGES
Re: Gateron Oil Kings - Clean and Re-lube?
« Reply #1 on: Thu, 02 November 2023, 03:49:58 »
there would be a benefit, a hand lube job will be more consistent as you are intentional when it comes to every area of a switch, compared to gaterons which is most likely automated which would most likely create hot spots where there is way to much of not enough lube.
I would personally do it, not necessarily because of the lube job, but that is definitely a factor, but mostly to replace the stock springs with consistent ones, and if I'm doing that I will just take the time to redo everything, but that's just me.
Offline Sup
« Reply #2 on: Thu, 02 November 2023, 17:35:17 »
In my opinion not worth it. I would just swap the spring and just break them in over time.
current
Coming soon
Offline Exquite
  • GeekAnubis
« Reply #3 on: Mon, 06 November 2023, 17:29:49 »
I think Oil King is a bit mushy on my hand. Relubing it will be better, and from my experience, it still reserves the thick thock sound.
I'm a Color lover and a designer.
Offline phinix
« Reply #4 on: Wed, 08 November 2023, 09:56:14 »
Not worth it. I bought Oil Kings and just swapped springs with 85g TX Springs - XL (18mm) and they are AWESOME.
