Author Topic: [GB] Kangaroo left handed fullsize  (Read 90482 times)
Offline JonoColwell
« on: Tue, 07 November 2023, 00:53:48 »
After 1 2 3 several years, It's finally ready.
It's already been ordered so expected time to ship to the warehouse is about 1-2 months. But the listing is live so it finally counts.
Kitting:
Alu top - Black
Alu base - Silver
4.5mm alu plate - Black
Yes there's only one kit, black goes with everything and black/silver has much lower failure rates, the board was always designed to be two tone anyway.
Link to buy
https://keyboardtreehouse.com/products/ae-x-impulse-boards-kangaroo
FR4 plates
https://keyboardtreehouse.com/products/copy-of-preorder-ae-x-impulse-boards-kangaroo-fr4-plate
Note, the prices are in AUD, which means this board is approximately
https://www.xe.com/currencyconverter/convert/?Amount=700&From=AUD&To=USD
this many USD
Specs
Weight: 2.75 kg (Unbuilt)
494.6 mm (L) x 144.1 mm (w)
Total case height when built: 43.6 + 1.5mm (Feet)
Front lip height: 22.3 +1.5mm (feet)
-7/+7 degree Typing angle via reversible base
Top mounted
USB-C PCB
64k eeprom for maximum macro storage
VIA compatible
GB End:
Well, it's not really a GB, we just ordered the units, so it's probably more like a preorder so it'll end when we have no more units I guess.
It comes in one colour combination, silver bottom, black plate and top, this is for a couple of reasons
1. Black goes with everything
2. I like two tone boards
The pinging issue has been resolved with the addition of a foam kit which includes some cut foam to act as a force break mod.
There are also some QMK shenanigans going on with the board which means that technically it has 128 macro keys assignable, unfortunately QMK only displays 0-15 but you can still assign them by assigning the keycodes directly, we're working in the background to try and get via working for larger macro spaces.
Also here's the full KLE
There are 100 boards available.
« Last Edit: Wed, 08 November 2023, 16:53:33 by JonoColwell »
Offline JonoColwell
Re: [GB] Kangaroo left handed 108
« Reply #1 on: Tue, 07 November 2023, 01:44:45 »
Reserved
Re: [GB] Kangaroo left handed fullsize
« Reply #2 on: Fri, 10 November 2023, 15:30:47 »
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
Offline JonoColwell
« Reply #3 on: Thu, 30 November 2023, 04:26:58 »
Thanks Apiary and Lightning for doing a couple of builds
https://www.twitch.tv/videos/1986208069
https://www.twitch.tv/lightningkeyboards/video/1990717583
Keyboards expected in warehouse within the next 2-3 weeks
